[PATCH] ftpd: RETR of a directory should fail
    Sebastian Huber
    Thu May  6 12:33:17 UTC 2010
On 05/06/2010 02:12 PM, Ralf Corsepius wrote:
> On 05/06/2010 01:48 PM, Sebastian Huber wrote:
>> On 05/06/2010 01:42 PM, Ralf Corsepius wrote:
>>> On 05/06/2010 01:27 PM, Sebastian Huber wrote:
>>>> Please do not send patches to this mailing list.  Instead they should
>>>> go into
>>>> the bugzilla data base:
>>> Sebastian, no idea were you've got this idea from.
>> It just makes sense.
> Many projects will disagree with you.
> The traditional arguments against bugzilla (floating around ever since
> bugzilla exists):
> - It requires a log-in. Many users refuse to get one.
Yes, this is annoying, but it is only a configuration issue.  For FreeBSD it is
possible to send bug reports without a log in (they use Gnats).
> - It means additional bureaucracy / overhead.
Yes, but this overhead helps to track the patches and reports.
> - It means having http:-access
> - It's ui and usabilty leaves much to be desired.
Yes, it is not perfect.  I am not a Bugzilla expert, but Gnats has also an
email interface (and more).
> - Less eyes to review patches.
We could forward the messages also to this list.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
