FAT Filesystem
Cláudio Silva
claudiodcsilva at hotmail.com
Wed May 5 11:36:36 UTC 2010
Hi,
Block Device Buffer interface has an "rtems_bdbuf_syncdev" function that
writes all modified buffer for a device and blocks until all transfers are
complete, but you still have the problem raised by Leon.
(http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__bdbuf.html#ga9a49c1519760b60eace0463277af50ee)
Cláudio.
Sent: Wednesday, May 05, 2010 12:20 PM
To: <rtems-users at rtems.org>
Cc: <rtems-users at rtems.com>
Subject: Re: FAT Filesystem
> On Wednesday May 5 2010, Wolfram Wadepohl wrote:
>> To all specialists of the FAT filesystem and medis buffering:
>> A power off at the wrong time can cause the filsystem to a inconsistent
>> state. Is there a mechanism , like the UNIX sync command, to write
>> buffers
>> to disk and transfer all buffering to a safe state.
>> How long does this take, esp. when using a CF/SD card.
>> Thx.
> To your last question.
> Please, note, that even when you receive the acknowledge from the CF
> controller about write operation success completion, actually it does not
> mean, that the data was actually written into the flash memories. This
> only
> means that controller has accepted data and put it into its internal
> memory.
> You need to keep the power ON for the controller to finish the
> operation...:-)
> Leon
> rtems-users mailing list
