RTEMS as a PLC?
Ian Caddy ianc at goanna.iinet.net.au
Fri May 14 01:03:23 UTC 2010
Hi Aaron,
On 14/05/2010 6:40 AM, Aaron J. Grier wrote:
> this is a long-shot, but has anybody out there done any investigation of
> implementing IEC 61131(-3) on RTEMS to create a programmable logic
> controller?  RTEMS seems like it would be suitable to handle both a
> hard-real-time PLC loop in addition to human-machine-interface duties.
We have used RTEMS for a number of years in a Remote Terminal Unit (RTU)
based product (for Supervisory Control and Data Acquisition - SCADA)
that also contains IEC61131-3 functionality.  In an RTU device the
reporting (communications) of time based eventing is more important than
the logic running in the unit so it is a bit different to a PLC type
device but RTEMS had no problems performing admirably with this.
We run the logic as a task with a certain priority in the system.
The 61131-3 system that we use is quite old and was bought in from
IsaGRAF but works OK.
Let me know if you have any more specific questions.
regards,
Ian Caddy
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
