Reference bsp_section_data_start from C yields "R_PPC_EMB_SDA21 relocation is in the wrong output section"
Eric Norum
wenorum at lbl.gov
Mon May 17 15:53:16 UTC 2010
On May 16, 2010, at 8:52 PM, Till Straumann wrote:
> I did that, too, but you have to know what you are doing.
> This trick *only* works if you know that your symbol is
> in the 'data' area and you want to avoid the compiler to
> assume it to be in the short data area.
> E.g., if you know our symbol is .text then you would declare
> it as a function, of course.
> Using a section __attribute__ is IMO preferable.
I must be missing something. Here's a section of the uc5282 BSP linkcmds:
SECTIONS
_header_offset = 0;
* Text, data and bss segments
.text _DownloadLocation : {
*(.text*)
*(.ram_code)
* C++ constructors/destructors
*(.gnu.linkonce.t.*)
* Initialization and finalization code.
* Various files can provide initialization and finalization
* functions. crtbegin.o and crtend.o are two instances. The
* body of these functions are in .init and .fini sections. We
* accumulate the bodies here, and prepend function prologues
* from crti.o and function epilogues from crtn.o. crti.o must
* be linked first; crtn.o must be linked last. Because these
* are wildcards, it doesn't matter if the user does not
* actually link against crti.o and crtn.o; the linker won't
* look for a file to match a wildcard. The wildcard also
* means that it doesn't matter which directory crti.o and
* crtn.o are in.
PROVIDE (_init = .);
*crti.o(.init)
*(.init)
*crtn.o(.init)
PROVIDE (_fini = .);
*crti.o(.fini)
*(.fini)
*crtn.o(.fini)
* Special FreeBSD sysctl sections.
. = ALIGN (16);
__start_set_sysctl_set = .;
*(set_sysctl_*);
__stop_set_sysctl_set = ABSOLUTE(.);
*(set_domain_*);
*(set_pseudo_*);
In a C program I tried:
extern char __start_set_sysctl_set[];
printf("%ld\n", (unsigned long)__start_set_sysctl_set);
This compiled and linked with no complaints even though the symbol is in the text segment:
m68k-rtems4.10-nm example | grep __start_set_sysctl_set
00143360 T __start_set_sysctl_set
Am I venturing into 'undefined behaviour' territory?
Eric Norum
wenorum at lbl.gov
