error at gdb sim
Mon Nov 8 12:39:01 UTC 2010
On 11/08/2010 01:33 PM, Eugene Shvets wrote:
> HI,
> I tried following the instructions at
> http://www.rtems.com/wiki/index.php/Quick_Start
This page uses the SIS BSP with the GDB SPARC simulator.
> ran gdb and executed
> tar sim
> load
> r
>  Then got an error
> Starting program:
> /opt/rtems-4.10/bfin-rtems4.10/bf537Stamp/lib/rtems-4.10/tests/ticker.exe
> Unhandled instruction "CLI dregs" ... aborting
> Illegal instruction
> Is it normal, or does it indicate something went wrong through the
> installation?
You need a BSP that works with the GDB simulator.  It seems that bf537Stamp is
not one of them.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
