bfin ezlite 537 gdb make all error
Gedare Bloom gedare at gwmail.gwu.edu
Mon Nov 8 14:31:21 UTC 2010
On Mon, Nov 8, 2010 at 4:01 AM, Sergey Ablalimov <abl-s at yandex.ru> wrote:
> 03.11.2010 21:19, Gedare Bloom:
>> Try following the wiki instructions for building the tools with Ubuntu.
>> http://www.rtems.com/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
>> Make sure to match up version numbers of tools with patches.  The wiki
>> instructions are slightly out-dated, but you can find the latest
>> patches for rtems-4.11 in the rtems source tree, under
>> contrib/crossrpms/patches.  The diff file names indicate for which
>> version of the toolset they are applicable.
>> -Gedare
>> On Wed, Nov 3, 2010 at 12:12 PM, Eugene Shvets<lhj7362 at gmail.com>  wrote:
>>>   First, I am using ubuntu 10.04LTS.
>>>> FSF gdb-7.2 supports bfin-rtems* out of the box.
>>> I downloaded gdb-7.2 sources from ftp.gnu.org, unpacked.
>>> Created b-gdb directory, out from it executed ../gdb-7.2/configure
>>> --target=bfin-rtems4.11  --prefix=/opt/rtems-4.11
>>> Then executed "make all"
>>> It gave out the same error. Is it "out-of-the-box" support? I also tried
>>> applying the patch before configuring. It doesn't help either.
>>> As for Fedora, I could only find
>>> rtems-4.11-bfin-rtems4.11-gdb-6.5-1.fc13.i686.rpm at
>>> ftp://ftp.rtems.com/pub/rtems/linux/4.11 .
>>> It is gdb 6.5 , not 7.2.
>>> I am building toolchain because I didn't find binary gdb7.2.
> Do you upate PATH with
>  export PATH=/opt/rtems-4.11/bin:${PATH}
> before make?
Yes, You need to do this to get gcc to compile, since it needs to find
the target binutils.
> rtems-users mailing list
> rtems-users at rtems.org
