Stack full or something else?
João Rasta freakforever at gmail.com
Fri Nov 12 16:50:31 UTC 2010
Hi,
I have an RTEMS POSIX API application which comes to a point that if a small
function (with some doubles passed as arguments) is called, the application
exits with an error. At first i thought of increasing the stack space. I did
this with CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem remains
even if i remove all the contents of the function.
1) Am i setting up the stack size correctly? I think i am, but i ask just in
case..
2) Is there any other explanation to why a function call crashes the
application besides having a full stack? Again, i erased the function
contents..
Best,
JM
URL: <http://lists.rtems.org/pipermail/users/attachments/20101112/8bd33dfc/attachment.html>
