Stack full or something else?
Tue Nov 16 14:36:52 UTC 2010
On 11/16/2010 06:37 AM, João Rasta wrote:
> Eheh i done it :) . The problems were in code generated from the
> matlab real-time workshop from a simulation i have with blocks working
> at different rates. So now i tried to run the model advisor tool and
> fixed some code generation process options that were wrong. For
> instance, it was generating code for emulation, which was not needed
> in the final implementation. And it was set for single-tasking instead
> of multitasking. I then attached this OK generated code to my
> communications layer, all under RTEMS as i was doing before but with
> the bad generated code, and now it works perfectly.
> Basically it was a RTW code generation problem.
Can you please add a page to the Wiki on MatLab?  I jhave added a
link to the new page so all you have to do is fill in some details.
http://wiki.rtems.org/wiki/index.php?title=MATLABCodeGeneration&action=edit&redlink=1
Is RTEMS support included with MATLAB? Special options,
any portability or target architecture issues, etc.
Any information on what is required to do this is useful.  I know
people use MATLAB generated code with RTEMS but that is the
extent of my  knowledge and what is in the Wiki right now.
Thanks.
> Sincerely, thank you all.
> Best,
> JM
> On Tue, Nov 16, 2010 at 12:09 PM, João Rasta <freakforever at gmail.com
> <mailto:freakforever at gmail.com>> wrote:
>     I increased the stack sizes, but now i seem to be having trouble
>     with the register windows. Now gdb complaints when performing a
>     "ret" after getting out of a function:
>     0x4000a534 <mdlOutputs+328>: std     %f8, [ %l5 + 8 ]
>     0x4000a53c <mdlOutputs+336>: ret <<<<---- SEG FAULT
>     0x4000a540 <mdlOutputs+340>: restore
>     Here's the Stack copy:
>     Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
>     Segmentation fault.)
>         6 mdlOutputs()
>     C:\opt\build\Real_GNC\code\GNC\source\guidance_s.c:373 0x4000a53c
>         5 gnc_output()
>     C:\opt\build\Real_GNC\model\backups\gnc_linux\gnc.c:307 0x40008d80
>         4 Execute_gnc()
>     C:\opt\build\Real_GNC\model\backups\gnc_linux\gnc_wrapper.c:116
>     0x4000a180
>         3 task_main()
>     C:\opt\build\Real_GNC\src\shell\gnc_scheduler_task.c:125 0x40006144
>         2 _Thread_Handler()
>     c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\score\src\threadhandler.c:156
>     0x4003bdb0
>         1 _Thread_Handler()
>     c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\score\src\threadhandler.c:87
>     0x4003bc88
>     What could be generating such a problem? Do i need to change any
>     RTEMS configuration related to the register windows?
>     Best,
>     JM
>     On Mon, Nov 15, 2010 at 9:18 PM, Gedare Bloom
>     <gedare at gwmail.gwu.edu <mailto:gedare at gwmail.gwu.edu>> wrote:
>         That should work with posix, at least to increase the amount
>         of space pre-allocated for task stacks.  You will also need to
>         ensure that you use a large enough value of
>         pthread_attr_t->stacksize when you call pthread_create().
>         The suggestion to declare your large arrays as static can work
>         in case your function is non-reentrant, otherwise you have to
>         worry about sharing.
>         -G
>         On Mon, Nov 15, 2010 at 3:15 PM, João Rasta
>         <freakforever at gmail.com <mailto:freakforever at gmail.com>> wrote:
>             Hi Gedare,
>             Will CONFIGURE_EXTRA_TASK_STACKS also work with the POSIX API?
>             Best,
>             JM
>             On Mon, Nov 15, 2010 at 6:34 PM, Gedare Bloom
>                 João,
>                 You can configure extra space for all of your tasks
>                 like this:
>                   #define CONFIGURE_EXTRA_TASK_STACKS
>                 (RTEMS_MINIMUM_STACK_SIZE * ??)
>                 Where you put ?? to make it a multiple of min stack
>                 size, or you can just put an arbitrary number of bytes.
>                 Otherwise you can increase the stack_size argument to
>                 rtems_task_create for a particular task.
>                 You might also try configuring with
>                 CONFIGURE_STACK_CHECKER_ENABLED defined.  It does some
>                 extra checks for stack bounds and might give you a
>                 tighter window for debugging where the problem is
>                 occurring.
>                 -Gedare
>                 On Mon, Nov 15, 2010 at 1:13 PM, João Rasta
>                     Hi Joel,
>                     Good point. I have a task that is heavy on memory
>                     operations (multi-size array operations and so
>                     on). It also has a lot of doubles so it can also
>                     be corrupting its stack. Too bad it is 'silent'
>                     when corrupting the memory one way or another..
>                     To eliminate the stack overflow issue, i guess it
>                     is not enough to increase the initial task stack
>                     size. Is there a way to control the subsequent
>                     called task stack sizes?
>                     Best,
>                     JM
>                     On Mon, Nov 15, 2010 at 5:43 PM, Joel Sherrill
>                     <joel.sherrill at oarcorp.com
>                     <mailto:joel.sherrill at oarcorp.com>> wrote:
>                         On 11/15/2010 11:24 AM, João Rasta wrote:
>                             After some hard debuggin' with gdb i found
>                             out that this error is occurring at
>                             _Semaphore_Translate_core_mutex_return_code()
>                             but i still don't know why it happens.
>                             Here's the disassembly of the code where
>                             the error is generated
>                             0x40040d88 <rtems_semaphore_obtain+192>:
>                             ld      [ %l3 ], %g1
>                             0x40040d8c <rtems_semaphore_obtain+196>:
>                             call    0x400410c8
>                             <_Semaphore_Translate_core_mutex_return_code>
>                             0x40040d90 <rtems_semaphore_obtain+200>:
>                             ld      [ %g1 + 0x34 ], %o0
>                             0x40040e20 <rtems_semaphore_obtain+344>: b
>                             0x40040e24 <rtems_semaphore_obtain+348>:
>                             ld      [ %l3 ], %g1
>                             0x40040ed8 <rtems_semaphore_obtain+528>: b
>                             0x40040edc <rtems_semaphore_obtain+532>:
>                             ld      [ %l3 ], %g1
>                             And Stack copy:
>                             received. Description: Segmentation fault.)
>                                3 rtems_semaphore_obtain()
>                             c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
>                             0x40040edc
>                                2 <symbol is not available> 0x00000008
>                                1 <symbol is not available> 0x0000000c
>                         If this is the backtrace, somehow the stack
>                         pointer has gotten
>                         corrupted.
>                             The last value i could get from %g1 is 0.
>                         If this task is not blowing its stack, then we
>                         are left with a couple
>                         of guesses:
>                         + another task is blowing its stack and
>                         corrupting memory
>                         that impacts this task.
>                         + stray write is corrupting something.
>                         When did you see the %g1 have 0?  What was the
>                         last instruction?
>                         Where was it loading from?
>                             Here's how i'm configuring semaphores:
>                             #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
>                                        15
>                         This only affects POSIX semaphores sem_XXX.
>                             Any hints on what it can be failing?
>                             Should i set CONFIGURE_MAXIMUM_SEMAPHORES
>                             as well?
>                         I doubt it since you appear to be completing a
>                         semaphore_obtain.
>                         That means (probably) that a semaphore_create
>                         worked.
>                          Do a backtrace in gdb.  I suspect you will
>                         find you are  coming from a subsystem
>                         like termios.
>                         -joel
>                             Best,
>                             JM
>                             On Fri, Nov 12, 2010 at 7:34 PM, Joel
>                             Sherrill <joel.sherrill at oarcorp.com
>                             <mailto:joel.sherrill at oarcorp.com>>> wrote:
>                                On 11/12/2010 01:05 PM, João Rasta wrote:
>                                    Hi Daron,
>                                    It is running on a LEON-3. The
>                             application exits raising the
>                                    following exception:
>                                    IU in error mode (tt = 0x07)
>                                    which is a memory access to an
>                             unaligned address. The last
>                                    instruction is this:
>                                    4003bd74  d0006034   ld  [%g1 +
>                             0x34], %o0
>                                What is the value of g1?  Is it unaligned?
>                                    I don't understand why i have this
>                             error. The code where this
>                                    error is being reported is compiled
>                             independently and then put
>                                    in a library, but it uses the same
>                             cross-compiler as the main
>                                    source code. I don't think i'm
>                             doing something wrong while
>                                    compiling the library files, i use
>                             the same compilation flags..
>                                    What can i be missing to have
>                             unaligned memory accesses?
>                                    Best,
>                                    JM
>                                    On Fri, Nov 12, 2010 at 6:43 PM,
>                             Daron Chabot
>                             <daron.chabot at gmail.com
>                             <mailto:daron.chabot at gmail.com>
>                             <mailto:daron.chabot at gmail.com>>
>                             <mailto:daron.chabot at gmail.com>>>> wrote:
>                                       On Fri, Nov 12, 2010 at 11:50
>                             AM, João Rasta
>                             <mailto:freakforever at gmail.com>>>> wrote:
>                                           Hi,
>                                           I have an RTEMS POSIX API
>                             application which comes to a
>                                    point
>                                           that if a small function
>                             (with some doubles passed as
>                                           arguments) is called, the
>                             application exits with an
>                                    error. At
>                                           first i thought of
>                             increasing the stack space. I did
>                                    this with
>                             CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but
>                             the problem
>                                    remains
>                                           even if i remove all the
>                             contents of the function.
>                                           1) Am i setting up the stack
>                             size correctly? I think i
>                                    am, but
>                                           i ask just in case..
>                                           2) Is there any other
>                             explanation to why a function call
>                                           crashes the application
>                             besides having a full stack?
>                                    Again, i
>                                           erased the function contents..
>                                       What architecture is this
>                             running on ?
>                                       What is the application exit
>                             error (message and/or return
>                                    code)?
>                                       It looks like all POSIX threads
>                             are created as floating-point
>                                       tasks (FP state saved across
>                             context switches), so there
>                                       "shouldn't" be a problem on that
>                             aspect...
>                                           Best,
>                                           JM
>                             _______________________________________________
>                                           rtems-users mailing list
>                             rtems-users at rtems.org
>                             <mailto:rtems-users at rtems.org>
>                             <mailto:rtems-users at rtems.org>>
>                             <mailto:rtems-users at rtems.org>>>
>                             http://www.rtems.org/mailman/listinfo/rtems-users
>                                --     Joel Sherrill, Ph.D.
>                             Director of Research&  Development
>                              On-Line Applications Research
>                                Ask me about RTEMS: a free RTOS
>                              Huntsville AL 35805
>                                  Support Available             (256)
>                             722-9985
>                         Joel Sherrill, Ph.D.             Director of
>                         joel.sherrill at OARcorp.com        On-Line
>                         Ask me about RTEMS: a free RTOS  Huntsville AL
>                         35805
>                           Support Available             (256) 722-9985
>                     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
Joel Sherrill, Ph.D.             Director of Research&  Development
