Networking with QEMU
Simon Perreault simon.perreault at viagenie.ca
Mon Nov 29 20:18:33 UTC 2010
Hi all,
I'm following the instructions at
http://rtems.org/wiki/index.php/QEMU#Running_RTEMS_TCP.2FIP_Applications
When I start qemu with the given command-line, I get:
> isa irq 9 already assigned
In trying to isolate the problem, I realized that this has probably
nothing to do with RTEMS.
> $ qemu -net nic,model=ne2k_isa
This is on Fedora 14 x86_64.
My question is: since ne2k_isa seems to be broken, what other
alternatives do I have?
I tried ne2k_pci, which seems to be working to some degree, but I don't
see any packets going out.
> Initialized console on port COM1 9600-8-N-1
> network device 'ne1' <12:34:56:78:90:AB> initialized on port 0x300, irq 5
> BOOTP timeout for server 255.255.255.255
> BOOTP call failed -- Connection timed out
Any advice appreciated.
Thanks,
Simon
DTN made easy, lean, and smart --> http://postellation.viagenie.ca
NAT64/DNS64 open-source        --> http://ecdysis.viagenie.ca
STUN/TURN server               --> http://numb.viagenie.ca
