RTEMS VM corrupt?
Scott Newell newell at cei.net
Tue Nov 30 03:06:36 UTC 2010
Has anyone noticed any disk corruption with the Fedora VM?
http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
I've been seeing odd errors and lockups.  I thought it might be from
the failed "yum -y update" (ran out of disk space), so I went back
and unzipped a fresh copy, ran md5sum on it, then booted it and did a
fsck.  Results below.
Comments?
$ md5sum C++.vmdk
e258ad60c3bcd3e82f4b0d6484fc9a51 *C++.vmdk
Here's the output from fsck -n:
fsck from util-linux-ng 2.16.2
Warning!  /dev/mapper/VolGroup-lv_root is mounted.
Warning: skipping journal recovery because doing a read-only filesystem check.
/dev/mapper/VolGroup-lv_root contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong (2371714, counted=2372087).
Fix? no
Free inodes count wrong (685078, counted=684969).
Fix? no
/dev/mapper/VolGroup-lv_root: ********** WARNING: Filesystem still
has errors **********
/dev/mapper/VolGroup-lv_root: 222458/907536 files (0.1%
non-contiguous), 1253246/3624960 blocks
