gcc-4.5.1 make all problem
Eugene Shvets
lhj7362 at gmail.com
Mon Nov 1 17:41:57 UTC 2010
I am sorry, was writing in a hurry .
Incosistency with gcc version is caused by me copypasting the command from
manual. In fact I executed
../gcc-4.5.1/configure --target=bfin-rtems4.11 \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--enable-threads --enable-languages="c,c++" \
--prefix=/opt/rtems-4.11
command.
I also tried both --target=bfin-rtems4.11 and --target=bfin-rtems4.10
(switching --prefix accordingly). The output was exactly the same(except for
version 4.11/4.10), I posted the result for 4.10.
I also did create a symbolic link to newlib directory.
I wont have access to the computer I was using before tomorrow. I'll post
autoconf\automake version tomorrow.
Could you please clarify what "You must have a cross assembler in your PATH
ahead of the native one." means?
URL: <http://lists.rtems.org/pipermail/users/attachments/20101101/16f40533/attachment-0001.html>
