bfin ezlite 537 gdb make all error
Gedare Bloom gedare at gwmail.gwu.edu
Wed Nov 3 16:19:57 UTC 2010
Try following the wiki instructions for building the tools with Ubuntu.
http://www.rtems.com/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
Make sure to match up version numbers of tools with patches.  The wiki
instructions are slightly out-dated, but you can find the latest
patches for rtems-4.11 in the rtems source tree, under
contrib/crossrpms/patches.  The diff file names indicate for which
version of the toolset they are applicable.
-Gedare
On Wed, Nov 3, 2010 at 12:12 PM, Eugene Shvets <lhj7362 at gmail.com> wrote:
>   First, I am using ubuntu 10.04LTS.
>>FSF gdb-7.2 supports bfin-rtems* out of the box.
> I downloaded gdb-7.2 sources from ftp.gnu.org, unpacked.
> Created b-gdb directory, out from it executed ../gdb-7.2/configure
> --target=bfin-rtems4.11  --prefix=/opt/rtems-4.11
> Then executed "make all"
> It gave out the same error. Is it "out-of-the-box" support? I also tried
> applying the patch before configuring. It doesn't help either.
> As for Fedora, I could only find
> rtems-4.11-bfin-rtems4.11-gdb-6.5-1.fc13.i686.rpm at
> ftp://ftp.rtems.com/pub/rtems/linux/4.11 .
> It is gdb 6.5 , not 7.2.
> I am building toolchain because I didn't find binary gdb7.2.
> rtems-users mailing list
> rtems-users at rtems.org
