Stack full or something else?
Mon Nov 15 17:43:16 UTC 2010
On 11/15/2010 11:24 AM, João Rasta wrote:
> After some hard debuggin' with gdb i found out that this error is
> occurring at _Semaphore_Translate_core_mutex_return_code() but i still
> don't know why it happens. Here's the disassembly of the code where
> the error is generated
> 0x40040d88 <rtems_semaphore_obtain+192>: ld      [ %l3 ], %g1
> 0x40040d8c <rtems_semaphore_obtain+196>: call    0x400410c8
> <_Semaphore_Translate_core_mutex_return_code>
> 0x40040d90 <rtems_semaphore_obtain+200>: ld      [ %g1 + 0x34 ], %o0
> 0x40040e20 <rtems_semaphore_obtain+344>: b       0x40040d8c
> 0x40040e24 <rtems_semaphore_obtain+348>: ld      [ %l3 ], %g1
> 0x40040ed8 <rtems_semaphore_obtain+528>: b       0x40040d8c
> 0x40040edc <rtems_semaphore_obtain+532>: ld      [ %l3 ], %g1
> And Stack copy:
> Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
> Segmentation fault.)
>     3 rtems_semaphore_obtain()
> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
> 0x40040edc
>     2 <symbol is not available> 0x00000008
>     1 <symbol is not available> 0x0000000c
If this is the backtrace, somehow the stack pointer has gotten
corrupted.
> The last value i could get from %g1 is 0.
If this task is not blowing its stack, then we are left with a couple
of guesses:
+ another task is blowing its stack and corrupting memory
that impacts this task.
+ stray write is corrupting something.
When did you see the %g1 have 0?  What was the last instruction?
Where was it loading from?
> Here's how i'm configuring semaphores:
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES            15
This only affects POSIX semaphores sem_XXX.
> Any hints on what it can be failing? Should i set
> CONFIGURE_MAXIMUM_SEMAPHORES as well?
I doubt it since you appear to be completing a semaphore_obtain.
That means (probably) that a semaphore_create worked.
  Do a backtrace in gdb.  I suspect you will find you are  coming from a
subsystem
like termios.
-joel
> Best,
> JM
> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 11/12/2010 01:05 PM, João Rasta wrote:
>         Hi Daron,
>         It is running on a LEON-3. The application exits raising the
>         following exception:
>         IU in error mode (tt = 0x07)
>         which is a memory access to an unaligned address. The last
>         instruction is this:
>         4003bd74  d0006034   ld  [%g1 + 0x34], %o0
>     What is the value of g1?  Is it unaligned?
>         I don't understand why i have this error. The code where this
>         error is being reported is compiled independently and then put
>         in a library, but it uses the same cross-compiler as the main
>         source code. I don't think i'm doing something wrong while
>         compiling the library files, i use the same compilation flags..
>         What can i be missing to have unaligned memory accesses?
>         Best,
>         JM
>         On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
>         <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
>         <mailto:daron.chabot at gmail.com>>> wrote:
>            On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
>         <freakforever at gmail.com <mailto:freakforever at gmail.com>
>         <mailto:freakforever at gmail.com>>> wrote:
>                Hi,
>                I have an RTEMS POSIX API application which comes to a
>         point
>                that if a small function (with some doubles passed as
>                arguments) is called, the application exits with an
>         error. At
>                first i thought of increasing the stack space. I did
>         this with
>                CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
>         remains
>                even if i remove all the contents of the function.
>                1) Am i setting up the stack size correctly? I think i
>         am, but
>                i ask just in case..
>                2) Is there any other explanation to why a function call
>                crashes the application besides having a full stack?
>         Again, i
>                erased the function contents..
>            What architecture is this running on ?
>            What is the application exit error (message and/or return
>         code)?
>            It looks like all POSIX threads are created as floating-point
>            tasks (FP state saved across context switches), so there
>            "shouldn't" be a problem on that aspect...
>                Best,
>                JM
>                _______________________________________________
>                rtems-users mailing list
>         rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>         <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>         http://www.rtems.org/mailman/listinfo/rtems-users
>     Joel Sherrill, Ph.D.             Director of Research&  Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>       Support Available             (256) 722-9985
