Stack full or something else?
João Rasta freakforever at gmail.com
Tue Nov 16 12:09:15 UTC 2010
I increased the stack sizes, but now i seem to be having trouble with the
register windows. Now gdb complaints when performing a "ret" after getting
out of a function:
0x4000a534 <mdlOutputs+328>: std     %f8, [ %l5 + 8 ]
0x4000a53c <mdlOutputs+336>: ret     <<<<---- SEG FAULT
0x4000a540 <mdlOutputs+340>: restore
Here's the Stack copy:
Thread [3] (Suspended: Signal 'SIGSEGV' received. Description: Segmentation
fault.)
    6 mdlOutputs() C:\opt\build\Real_GNC\code\GNC\source\guidance_s.c:373
0x4000a53c
    5 gnc_output() C:\opt\build\Real_GNC\model\backups\gnc_linux\gnc.c:307
0x40008d80
    4 Execute_gnc()
C:\opt\build\Real_GNC\model\backups\gnc_linux\gnc_wrapper.c:116
0x4000a180
    3 task_main() C:\opt\build\Real_GNC\src\shell\gnc_scheduler_task.c:125
0x40006144
    2 _Thread_Handler()
c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\score\src\threadhandler.c:156
0x4003bdb0
    1 _Thread_Handler()
c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\score\src\threadhandler.c:87
0x4003bc88
What could be generating such a problem? Do i need to change any RTEMS
configuration related to the register windows?
Best,
JM
On Mon, Nov 15, 2010 at 9:18 PM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> That should work with posix, at least to increase the amount of space
> pre-allocated for task stacks.  You will also need to ensure that you use a
> large enough value of pthread_attr_t->stacksize when you call
> pthread_create().
> The suggestion to declare your large arrays as static can work in case your
> function is non-reentrant, otherwise you have to worry about sharing.
> -G
> On Mon, Nov 15, 2010 at 3:15 PM, João Rasta <freakforever at gmail.com>wrote:
>> Hi Gedare,
>> Will CONFIGURE_EXTRA_TASK_STACKS also work with the POSIX API?
>> Best,
>> JM
>> On Mon, Nov 15, 2010 at 6:34 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>>> João,
>>> You can configure extra space for all of your tasks like this:
>>>   #define CONFIGURE_EXTRA_TASK_STACKS (RTEMS_MINIMUM_STACK_SIZE * ??)
>>> Where you put ?? to make it a multiple of min stack size, or you can just
>>> put an arbitrary number of bytes.
>>> Otherwise you can increase the stack_size argument to rtems_task_create
>>> for a particular task.
>>> You might also try configuring with CONFIGURE_STACK_CHECKER_ENABLED
>>> defined.  It does some extra checks for stack bounds and might give you a
>>> tighter window for debugging where the problem is occurring.
>>> -Gedare
>>> On Mon, Nov 15, 2010 at 1:13 PM, João Rasta <freakforever at gmail.com>wrote:
>>>> Hi Joel,
>>>> Good point. I have a task that is heavy on memory operations (multi-size
>>>> array operations and so on). It also has a lot of doubles so it can also be
>>>> corrupting its stack. Too bad it is 'silent' when corrupting the memory one
>>>> way or another..
>>>> To eliminate the stack overflow issue, i guess it is not enough to
>>>> increase the initial task stack size. Is there a way to control the
>>>> subsequent called task stack sizes?
>>>> Best,
>>>> JM
>>>> On Mon, Nov 15, 2010 at 5:43 PM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com> wrote:
>>>>> On 11/15/2010 11:24 AM, João Rasta wrote:
>>>>>> After some hard debuggin' with gdb i found out that this error is
>>>>>> occurring at _Semaphore_Translate_core_mutex_return_code() but i still don't
>>>>>> know why it happens. Here's the disassembly of the code where the error is
>>>>>> generated
>>>>>> 0x40040d88 <rtems_semaphore_obtain+192>: ld      [ %l3 ], %g1
>>>>>> 0x40040d8c <rtems_semaphore_obtain+196>: call    0x400410c8
>>>>>> <_Semaphore_Translate_core_mutex_return_code>
>>>>>> 0x40040d90 <rtems_semaphore_obtain+200>: ld      [ %g1 + 0x34 ], %o0
>>>>>> 0x40040e20 <rtems_semaphore_obtain+344>: b       0x40040d8c
>>>>>> 0x40040e24 <rtems_semaphore_obtain+348>: ld      [ %l3 ], %g1
>>>>>> 0x40040ed8 <rtems_semaphore_obtain+528>: b       0x40040d8c
>>>>>> 0x40040edc <rtems_semaphore_obtain+532>: ld      [ %l3 ], %g1
>>>>>> And Stack copy:
>>>>>> Segmentation fault.)
>>>>>>    3 rtems_semaphore_obtain()
>>>>>> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
>>>>>> 0x40040edc
>>>>>>    2 <symbol is not available> 0x00000008
>>>>>>    1 <symbol is not available> 0x0000000c
>>>>>>  If this is the backtrace, somehow the stack pointer has gotten
>>>>> corrupted.
>>>>>  The last value i could get from %g1 is 0.
>>>>> If this task is not blowing its stack, then we are left with a couple
>>>>> of guesses:
>>>>> + another task is blowing its stack and corrupting memory
>>>>> that impacts this task.
>>>>> + stray write is corrupting something.
>>>>> When did you see the %g1 have 0?  What was the last instruction?
>>>>> Where was it loading from?
>>>>>  Here's how i'm configuring semaphores:
>>>>>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES            15
>>>>>>  This only affects POSIX semaphores sem_XXX.
>>>>>> Any hints on what it can be failing? Should i set
>>>>>> CONFIGURE_MAXIMUM_SEMAPHORES as well?
>>>>>>  I doubt it since you appear to be completing a semaphore_obtain.
>>>>> That means (probably) that a semaphore_create worked.
>>>>>  Do a backtrace in gdb.  I suspect you will find you are  coming from a
>>>>> subsystem
>>>>> like termios.
>>>>> -joel
>>>>>> Best,
>>>>>> JM
>>>>>> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill <
>>>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>>>>    On 11/12/2010 01:05 PM, João Rasta wrote:
>>>>>>        Hi Daron,
>>>>>>        It is running on a LEON-3. The application exits raising the
>>>>>>        following exception:
>>>>>>        IU in error mode (tt = 0x07)
>>>>>>        which is a memory access to an unaligned address. The last
>>>>>>        instruction is this:
>>>>>>        4003bd74  d0006034   ld  [%g1 + 0x34], %o0
>>>>>>    What is the value of g1?  Is it unaligned?
>>>>>>        I don't understand why i have this error. The code where this
>>>>>>        error is being reported is compiled independently and then put
>>>>>>        in a library, but it uses the same cross-compiler as the main
>>>>>>        source code. I don't think i'm doing something wrong while
>>>>>>        compiling the library files, i use the same compilation flags..
>>>>>>        What can i be missing to have unaligned memory accesses?
>>>>>>        Best,
>>>>>>        JM
>>>>>>        On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
>>>>>>        <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
>>>>>>        <mailto:daron.chabot at gmail.com>>> wrote:
>>>>>>           On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
>>>>>>        <freakforever at gmail.com <mailto:freakforever at gmail.com>
>>>>>>        <mailto:freakforever at gmail.com>>> wrote:
>>>>>>               Hi,
>>>>>>               I have an RTEMS POSIX API application which comes to a
>>>>>>        point
>>>>>>               that if a small function (with some doubles passed as
>>>>>>               arguments) is called, the application exits with an
>>>>>>        error. At
>>>>>>               first i thought of increasing the stack space. I did
>>>>>>        this with
>>>>>>               CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
>>>>>>        remains
>>>>>>               even if i remove all the contents of the function.
>>>>>>               1) Am i setting up the stack size correctly? I think i
>>>>>>        am, but
>>>>>>               i ask just in case..
>>>>>>               2) Is there any other explanation to why a function call
>>>>>>               crashes the application besides having a full stack?
>>>>>>        Again, i
>>>>>>               erased the function contents..
>>>>>>           What architecture is this running on ?
>>>>>>           What is the application exit error (message and/or return
>>>>>>        code)?
>>>>>>           It looks like all POSIX threads are created as
>>>>>> floating-point
>>>>>>           tasks (FP state saved across context switches), so there
>>>>>>           "shouldn't" be a problem on that aspect...
>>>>>>               Best,
>>>>>>               JM
>>>>>>               _______________________________________________
>>>>>>               rtems-users mailing list
>>>>>>        rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>>>>        <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>>>>>>        http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>>    --     Joel Sherrill, Ph.D.             Director of Research&
>>>>>>  Development
>>>>>>    joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>    Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>      Support Available             (256) 722-9985
>>>>> Joel Sherrill, Ph.D.             Director of Research&  Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20101116/802acc9c/attachment-0001.html>
