Custom RTEMS task stack location?
Gedare Bloom
gedare at gwmail.gwu.edu
Wed Nov 17 20:07:48 UTC 2010
The relevant code in the Thread Initialization is at
cpukit/score/src/threadinitialize.c:
87 /*
88 * Allocate and Initialize the stack for this thread.
89 */
90 #if !defined(RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API)
91 actual_stack_size = _Thread_Stack_Allocate( the_thread, stack_size
92 if ( !actual_stack_size || actual_stack_size < stack_size )
93 return false; /* stack allocation failed */
94
95 stack = the_thread->Start.stack;
96 #else
97 if ( !stack_area ) {
98 actual_stack_size = _Thread_Stack_Allocate( the_thread, stack_size
99 if ( !actual_stack_size || actual_stack_size < stack_size )
100 return false; /* stack allocation failed */
101
102 stack = the_thread->Start.stack;
103 the_thread->Start.core_allocated_stack = true;
104 } else {
105 stack = stack_area;
106 actual_stack_size = stack_size;
107 the_thread->Start.core_allocated_stack = false;
108 }
109 #endif
On Wed, Nov 17, 2010 at 3:06 PM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> I think this can be done with the User_extensions_thread_create_extension.
> How you do it I'm not sure exactly.
> With the Class API task create, I don't think that it can be done
> directly. However, the functionality is certainly supported from some other
> interfaces.
> cpukit/rtems/src/taskcreate.c
> 174 status = _Thread_Initialize(
> 175 &_RTEMS_tasks_Information,
> 176 the_thread,
> 177 NULL,
> 178 stack_size,
> 179 is_fp,
> 180 core_priority,
> 181 _Modes_Is_preempt(initial_modes) ? true : false,
> 182 _Modes_Is_timeslice(initial_modes) ?
> 183 THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE :
> 184 THREAD_CPU_BUDGET_ALGORITHM_NONE,
> 185 NULL, /* no budget algorithm callout */
> 186 _Modes_Get_interrupt_level(initial_modes),
> 187 (Objects_Name) name
> 188 );
> The third argument to _Thread_Initialize is interpreted as an initial stack
> location, but the classic API does not use the field (POSIX does I believe).
> -Gedare
> On Wed, Nov 17, 2010 at 2:23 PM, Cudmore, Alan P. (GSFC-5820) <
> alan.p.cudmore at nasa.gov> wrote:
>> When creating a task, can the stack be allocated from an absolute address
>> rather than having RTEMS allocate it from the workspace?
>> Thanks,
>> Alan
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101117/9eac12cf/attachment-0001.html>
