Serial device access with qemu!
Jeferson Luiz Rodrigues Souza
jeferodrigues at gmail.com
Tue Nov 23 15:11:49 UTC 2010
Dear Wendell
On Tue, Nov 23, 2010 at 12:18 PM, Wendell Pereira da Silva <
wendell.silva at compsisnet.com.br> wrote:
> Dear Jeferson,
> Well, let us try tty_driver :-)
> Put #include <bsp/tty_drv.h> in your include list before #include
> <rtems/confdefs.h>
> Rigth after CONFIGURE_NUMBER_OF_TERMIOS_PORTS put the following:
> #define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
> TTY1_DRIVER_TABLE_ENTRY, \
> TTY2_DRIVER_TABLE_ENTRY
> Let me know if it works.
I cannot test it because in my compilation of RTEMS 4.9.4 (pc586 bsp) I do
not see the header file <bsp/tty_driver.h>. I only see the following files:
<bsp/bootcard.h>
<bsp/irq.h>
<bsp/irq_asm.h>
I found in the list references to use this tty_driver but I cannot test
because the file that support some definitions needed by the proposed
solution do not exist in my compilation.
Best regards,
Jeferson.
> Wendell.
> *De:* Jeferson Luiz Rodrigues Souza [mailto:jeferodrigues at gmail.com]
> *Enviada em:* terça-feira, 23 de novembro de 2010 09:12
> *Para:* Wendell Pereira da Silva
> *Cc:* rtems-users at rtems.org
> *Assunto:* Re: Serial device access with qemu!
> Hi Wendell,
> thanks for your reply.
> On Tue, Nov 23, 2010 at 11:04 AM, Wendell Pereira da Silva <
> Hi Jeferson,
> Note that “/dev/ttyS0” in the QEMU is not the same path registered by the
> pc586 (pc386 variant) BSP.
> Do you have tried “/dev/ttyS1”?
> Yes, I tried with "/dev/ttyS1" and the same problem happens. I also tested
> the serial port in the host and it is ok.
> Any idea?
> Rest regards,
> Jeferson.
> Best regards,
> Wendell.
> *De:* rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
> *Em nome de *Jeferson Luiz Rodrigues Souza
> *Enviada em:* terça-feira, 23 de novembro de 2010 06:50
> *Para:* rtems-users at rtems.org
> *Assunto:* Serial device access with qemu!
> Hi everyone,
> I am trying to access a serial port in RTEMS 4.9.4 using a pc586 bsp.
> However, when I execute the application using qemu the code cannot open the
> device, and the perror() function presents the following message: "No such
> file or directory". It seems that RTEMS did not initialize a properly driver
> to handle serial device. Is it right?
> The qemu command line is:
> sudo qemu -serial "/dev/ttyS0" -fda floppy.img -boot a
> I made a search in this list and I found references about serial port
> access but nothing to help in my case. Could anyone help me or point me some
> documentation about serial port access in RTEMS?
> The code used in the test is presented below. I do not have some experience
> with RTEMS and I do not know the source of this problem.
> Thanks,
> jefecomp.
> #include <signal.h>
> #include <stdlib.h>
> #include <stdio.h>
> #include <pthread.h>
> #include <uart.h>
> #include <termios.h>
> #include<sched.h>
> #include <bsp.h>
> #include <fcntl.h>
> #include <sys/types.h>
> #include <sys/stat.h>
> #define CONFIGURE_INIT
> #include <rtems.h>
> void *POSIX_Init();
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATIONS_NEEDS_RTC_DRIVER
> #define CONFIGURE_MICROSECONDS_PER_TICK 1000
> #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
> #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 10
> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 10
> #define CONFIGURE_MAXIMUM_POSIX_TIMERS 10
> #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 40
> #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 10
> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 3
> #include<rtems/confdefs.h>
> void *POSIX_Init()
> printf("Serial Port Test!!!\n");
> char buffer[255];
> int bytesRead;
> int serial_fp = open("/dev/ttyS0",O_RDONLY);
> printf("SERIAL_FP = %i\n",serial_fp);
> if(serial_fp < 0)
> printf("FAILURE TO OPEN SERIAL PORT\n");
> perror(serial_fp);
> exit(-1);
> //write(serial_fp,buffer,strlen(buffer)+1);
> bytesRead = read(serial_fp, buffer, 255);
> if(bytesRead < 0)
> printf("Problems in the read of Serial Port");
> close(serial_fp);
> exit(1);
> else
> buffer[bytesRead] = 0;
> printf(buffer);
> close(serial_fp);
> exit(0);
URL: <http://lists.rtems.org/pipermail/users/attachments/20101123/cbc39518/attachment-0001.html>
