NTP
Daron Chabot
daron.chabot at gmail.com
Tue Oct 12 16:07:22 UTC 2010
I use NTP to set system time on several species of RTEMS targets. Works as
expected.
This sounds like it may be a configuration problem, either in the
ntp-server, network routing, or the target. Simplest thing to check is if
your ntp server is actually up and healthy.
Can you send me your NTP server config (/etc/ntp.conf) and your target's
network config?
-- dc
On Tue, Oct 12, 2010 at 11:09 AM, Martin Grim <W.M.Grim at sron.nl> wrote:
> Hi,
> Did someone mange to get updated date/time via NTP in its target? If so,
> how?
> I've set the ntp servers in the rtems_bsc_config structure and I call the
> rtems_bsdnet_synchronize_ntp function somewhere in the beginning of my app,
> but to no avail. I get either a "no more processes" (EAGAIN) or a "host not
> reachable" out of the rtems_bsdnet_get_ntp() function.
> Any clues what I might be doing wrong?
> Regards,
> Martin
> ir. W.M. Grim
> SRON Netherlands Institute for Space Research
> Sorbonnelaan 2
> 3584 CA Utrecht, The Netherlands
> www.sron.nl
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101012/07a51654/attachment.html>
