Issues with the Getting Starting Guide
Sam Lost
slostuk at gmail.com
Wed Oct 20 19:48:20 UTC 2010
Ok I have located an updated version of M4 however I am still unable to
generate the confiure file required.
I am run M4 version m4 (GNU M4) 1.4.14
Regards
Sam
On Wed, Oct 20, 2010 at 8:27 PM, Sam Lost <slostuk at gmail.com> wrote:
> Thanks
> Thanks, I have downloaded the source from CVS, however files such as
> configure do not appear to get extracted.
> I understand that I need to run autoconf to generate the configure file.
> However when I do so I get the following error
> autoconf ../rtems-4.10/configure.ac
> /bin/m4: unrecognized option `--gnu'
> Try `/bin/m4 --help' for more information.
> autom4te-2.67: /bin/m4 failed with exit status: 1
> I have been unable to update the versionof M4 the link in the following
> document
> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_M4
> to m4-1.4.7-MSYS.tar.bz2 is incorrect,
> Can anyone direct me toward the file that I need.
> Regards
> Sam
> On Tue, Oct 19, 2010 at 6:59 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>> You can get the RTEMS source from CVS:
>> http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
>> See the bottom section about tags if you want 4.10. The CVS head is called
>> 4.11 at this point in time.
>> You might find this getting started a little more up-to-date (and
>> streamlined): http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
>> -Gedare
>> On Tue, Oct 19, 2010 at 1:46 PM, Sam Lost <slostuk at gmail.com> wrote:
>>> I have been attempting to follow the Getting Started Guide
>>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
>>> I reached the stage where I would like to download the source however the
>>> link given in the above page of the Getting Start Guide is incorrect.
>>> Can someone point me towards the 4.10 RTEMS soure.
>>> Regards
>>> Sam
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101020/c6d42d89/attachment.html>
