Yet more MinGW Build Issues
Ian Caddy ianc at goanna.iinet.net.au
Thu Oct 21 00:57:49 UTC 2010
Sam,
On 20/10/2010 11:51 PM, Sam Lost wrote:
> After a bit of a battle I have managed to install the RTEMS MinGW tools.
> I have been using the following document as a guide along with a lot of
> help from Ian (Many Thanks):
> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_M4
> I have followed the directions for MSYS however when I run make install
> I get the following errors:
> make[2]: *** No rule to make target `install'.Stop.
> make[1]: *** [install-recursive] Error 1
> make: *** [install-recursive] Error 1
> Any ideas what might have gone wrong?
What steps exactly did you perform to try to build RTEMS?
What was your configure command?
Can you provide the config.log?
We need more details here to be able to help.
regards,
Ian C.
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
