Yet more MinGW Build Issues
Thu Oct 21 07:10:00 UTC 2010
On 20/10/10 11:49 PM, Sam Lost wrote:
> Ok, however when I use 4.9 I get the same result:
> I issued the following commands
> export PATH="/c/opt/rtems-4.9/bin:$PATH
> *** Note I think the following document has an error:
> http://www.rtems.org/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_Base
> as you have to add /c/ to the documented path **
If you look under here:
http://www.rtems.org/wiki/index.php?title=MinGW_Tools_for_Windows&oldid=7721#MSYS_Shell
you can see the /etc/fstab needs to be modified. The documentation
excepts you to have made this change.
> tar xjf rtems-4.9.4.tar.bz2
> mkdir rtems-4.9.4-psim
> cd rtems-4.9.4-psim
> ../rtems-4.9.4/configure --target=powerpc-rtems4.9
> --enable-rtemsbsp=psim --enable-cxx --enable-tests=samples
> make install
Could we please work with 4.10 or 4.11 ?
Thanks
