Yet more MinGW Build Issues
Sam Lost
slostuk at gmail.com
Thu Oct 21 07:24:06 UTC 2010
I would be happy to use 4.10 however, the link given in the following
document is incorrect:
http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
I used CVS to download the 4.10 tag and followed the directions in this
document with regard to bootstrap
http://www.rtems.com/wiki/index.php/Quick_Start
However the script failed.
Is version 4.9.4 currently supported, can it be built under MinGW?
Regards
Sam
On Thu, Oct 21, 2010 at 8:10 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 20/10/10 11:49 PM, Sam Lost wrote:
>> Ok, however when I use 4.9 I get the same result:
>> I issued the following commands
>> export PATH="/c/opt/rtems-4.9/bin:$PATH
>> *** Note I think the following document has an error:
>> http://www.rtems.org/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_Base
>> as you have to add /c/ to the documented path **
> If you look under here:
> http://www.rtems.org/wiki/index.php?title=MinGW_Tools_for_Windows&oldid=7721#MSYS_Shell
> you can see the /etc/fstab needs to be modified. The documentation excepts
> you to have made this change.
> tar xjf rtems-4.9.4.tar.bz2
>> mkdir rtems-4.9.4-psim
>> cd rtems-4.9.4-psim
>> ../rtems-4.9.4/configure --target=powerpc-rtems4.9
>> --enable-rtemsbsp=psim --enable-cxx --enable-tests=samples
>> make install
> Could we please work with 4.10 or 4.11 ?
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/8c1726fe/attachment.html>
