Yet more MinGW Build Issues
Thu Oct 21 07:40:44 UTC 2010
On 10/21/2010 09:32 AM, Sebastian Huber wrote:
> On 10/21/2010 09:24 AM, Sam Lost wrote:
>> Is version 4.9.4 currently supported, can it be built under MinGW?
> Yes, it can be built under MinGW.  Check that you have everything in your PATH
> and that you use the right tool versions (autoconf, automake, m4, RTEMS tool
> chain).
> An alternative is to install a RPM based Linux in a virtual machine.
If I would start using RTEMS with MinGW, I would download the tools in:
ftp://www.rtems.eu/pub/rtems/mingw32/4.11/
and use the CVS head.
That is what I currently do, and it works quite well (except that GDB has
problems with Windows 7 64-bit and the QEMU GDB server).
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
