Yet more MinGW Build Issues
Sam Lost
slostuk at gmail.com
Thu Oct 21 07:41:43 UTC 2010
I my path is givin below
/c/msys/1.0/bin:/opt/rtems-4.9/bin:.:/usr/local/bin:/mingw/bin:/bin:/c/Program
Files/Common Files/Microsoft Shared/Windows
Live:/c/Perl/site/bin:/c/Perl/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program
Files/QuickTime/QTSystem/:/c/Program Files/Common Files/Roxio
Shared/DLLShared/:/c/Program Files/SMARTEAM/bin:/c/Program Files/Microsoft
SQL Server/90/Tools/binn/:/c/Program
Files/doxygen/bin:/c/PROGRA~1/cvsnt:/c/Program Files/CVSNT/:/c/Program
Files/Microsoft SQL Server/100/Tools/Binn/:/c/Program Files/Microsoft SQL
Server/100/DTS/Binn/:/c/WINDOWS/system32/WindowsPowerShell/v1.0:/c/Program
Files/TortoiseSVN/bin:
I have untarred the automake and autoconf tools into /c/opt/rtems-4.9/bin
along with the 4.9 PowerPC Tools.
I have untarred the lastet version of M4, as the version quoted in
http://www.rtems.org/wiki/index.php?title=MinGW_Tools_for_Windows&oldid=7721#MSYS_Shell
is not available via the link given.
Regards
Sam
On Thu, Oct 21, 2010 at 8:32 AM, Sebastian Huber <
> On 10/21/2010 09:24 AM, Sam Lost wrote:
> > Is version 4.9.4 currently supported, can it be built under MinGW?
> Yes, it can be built under MinGW. Check that you have everything in your
> PATH
> and that you use the right tool versions (autoconf, automake, m4, RTEMS
> tool
> chain).
> An alternative is to install a RPM based Linux in a virtual machine.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/9e6855d5/attachment.html>
