Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Fri Oct 22 13:36:29 UTC 2010
Sebastian provided a copy of M4 1.4.7 after installing M4 1.4.7 I now get
the following error
/usr/bin/m4: unrecongized option --gnu
Any ideas I have been battl;ing trying to build either 4.9 or 4.10 under
windows for a while now :-(
Regards
Sam
On Fri, Oct 22, 2010 at 5:45 AM, Sam Lost <slostuk at gmail.com> wrote:
> I have extracted the RTEMS 4.10 Label from CVS as detailed:
> http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
> I am now attempting to run the bootstrap script:
> http://www.rtems.com/wiki/index.php/Quick_Start
> However I receive the following errors:
> ./c
> ./c/src/ada-tests
> is already registered with AC_CONFIG_FILES.
> ../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
> configure.ac:57: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> aclocal: autom4te failed with exit status:1
> automake: autoconf failed with exit status: 1
> Any ideas?
> Regards
> Sam
URL: <http://lists.rtems.org/pipermail/users/attachments/20101022/62a6e9b2/attachment.html>
