Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Fri Oct 22 13:59:37 UTC 2010
Thanks,
I tried all that, Chris kindly went throught it all step by step yesterday.
I am runinng Windows XP SP3
Regards
Sam
On Fri, Oct 22, 2010 at 2:44 PM, Sebastian Huber <
> I would delete everything and follow the steps from Chris Johns. Btw.
> which
> Windows version do you use?
> On 10/22/2010 03:36 PM, Sam Lost wrote:
> > Sebastian provided a copy of M4 1.4.7 after installing M4 1.4.7 I now
> > get the following error
> > /usr/bin/m4: unrecongized option --gnu
> > Any ideas I have been battl;ing trying to build either 4.9 or 4.10 under
> > windows for a while now :-(
> > Regards
> > Sam
> > On Fri, Oct 22, 2010 at 5:45 AM, Sam Lost <slostuk at gmail.com
> > <mailto:slostuk at gmail.com>> wrote:
> > I have extracted the RTEMS 4.10 Label from CVS as detailed:
> > http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
> > I am now attempting to run the bootstrap script:
> > http://www.rtems.com/wiki/index.php/Quick_Start
> > However I receive the following errors:
> > ./c
> > ./c/src/ada-tests
> > is already registered with AC_CONFIG_FILES.
> > ../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
> > configure.ac:57 <http://configure.ac:57/>: the top level
> > autom4te: /usr/bin/m4 failed with exit status: 1
> > aclocal: autom4te failed with exit status:1
> > automake: autoconf failed with exit status: 1
> > Any ideas?
> > Regards
> > Sam
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
URL: <http://lists.rtems.org/pipermail/users/attachments/20101022/c74b91fe/attachment.html>
