(offlist) RE: Running the Bootstrap Script under MinGW
Mon Oct 25 06:58:03 UTC 2010
On 10/23/2010 04:30 PM, Sam Lost wrote:
> I extracted the source from CVS using tortise CVS.
Tortoise CVS has an option to automatically convert <nl> in <cr><nl> (I guess
this is the default).  Please make sure that your sources use the UNIX line
endings.
> I have not edited the files in anyway.
> Regards
> Sam
> On Sat, Oct 23, 2010 at 7:35 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 23/10/10 06:53, Sam Lost wrote:
>     > Ok, I am still unable to compile the 4.10 code under MinGW.
>     How did you obtain the sources? Maybe this is a UNIX/DOS line ending
>     problem. Try to convert all text files to UNIX line endings.
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-users
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
