Strict aliasing and chains revisited
Wed Oct 27 13:18:32 UTC 2010
On 10/27/2010 02:10 AM, Chris Johns wrote:
> On 25/10/10 11:49 PM, Sebastian Huber wrote:
>> On 10/26/2010 07:15 AM, Chris Johns wrote:
>>> Why the packed attribute ?
>> In the thread from 2006
>> http://www.rtems.com/ml/rtems-users/2006/november/msg00096.html
>> some said that this my be necessary on some architectures to guarantee
>> the
>> overlapping.  I am not sure about this.  We may omit the packed
>> attribute and
>> see what the test suites say.
> I would rather we see a reason, discuss it and then decide what happens.
> Adding packed to anything makes it become very difficult to remove and
> know nothing breaks.
I removed the packed attribute and the test suite passes on ARM, SPARC and MIPS.
In the thread from 2006 the packed attribute was put into the discussion due to
some concerns with the ARM EABI.  I found nothing that indicates a 8 byte
structure alignment.  We only have a 8 byte stack alignment with the EABI.  I
run the test suite on ARM with my new EABI based tool chain and it works
without the packed attribute
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
