blackfin bf537ezlite bsp
Eugene Shvets
lhj7362 at gmail.com
Fri Oct 29 21:29:38 UTC 2010
On Fri, Oct 29, 2010 at 7:48 PM, Joel Sherrill wrote:
> On 10/29/2010 10:43 AM, Eugene Shvets wrote:
>> Hey everyone!
>> I want to insall RTEMS at blackfin bf537 ezlite board. I am totally new to
>> this things, but from what I aknowledged from wiki, I need first to create
>> an appropriate BSP since there is support only for bf537stamp board.
>> Hopefuly, I'll manage to do this with the help of onlinedocs.
>> Then I should build RTEMS providing it with the ready BSP with
>> --enable-rtemsbsp option (providing the directory to the file?).
>> Am I right?
>> Another question is how can I then download the built RTEMS into the
>> board? Is Uboot the way to go?
>> Thanks, and again, I am sorry for stupid questions.
> No stupid questions but you will have to help us answer your
> question. :D
> There is another bfin BSP -- eZKit533. Is it closer?
> How close is the bf537 ezlite to the stamp? If both
> are basically a PCB around the SOC, then likely you
> can just use a BSP variant and handle the differences
> as needed. A variation is some build/configure magic which
> lets you have an alternative build of a single BSP source
> directory.
> So how close are the existing board?
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> Thank you for your answer. Tbh I don't know how close both kits are. I
just got the basics and was planning the work-to-do.
I thought that different versions wouldn't fit. Ofc I'll try now to tweak
those BSP's first. I am wondering if I get the order right - first I make
BSP then build RTEMS(with custom BSP) and then download RTEMS into the
board?
URL: <http://lists.rtems.org/pipermail/users/attachments/20101030/e04ff8c4/attachment.html>
