problems with printfs inside rtems_timer_server_fire_after() callback
Sebastian Huber
Thu Oct 7 10:08:28 UTC 2010
On 10/07/2010 11:49 AM, Aitor Viana wrote:
> The version am using is RTEMS 4.8
> Is that version fixed?
No. The changes were only committed to the CVS head.
> Aitor
> On Thu, Oct 7, 2010 at 11:33 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hi,
> which version of RTEMS do you use? The timer server was quite
> broken before
> 2009-11-30. See also
> http://www.rtems.org/pipermail/rtems-users/2009-November/006248.html
> Have a nice day!
> On 10/07/2010 11:24 AM, Aitor Viana wrote:
> > Hi all,
> > I am getting _Internal_error_Occurred from rtems_semaphore_obtain
> function.
> > I back-traced the error and it appears when the callback register
> > with rtems_timer_server_fire_after() calls printf() function.
> Removing
> > the printf's solve the problem.
> > Reading at the RTEMS manual I understand that by using timer servers
> > should be possible to perform operations that you would in a normal
> > RTEMS task. Is that so?
> > Thanks,
> > aitor
> > rtems-users mailing list
> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
