Issues with the Getting Starting Guide
Sam Lost
slostuk at gmail.com
Wed Oct 20 19:27:14 UTC 2010
Thanks
Thanks, I have downloaded the source from CVS, however files such as
configure do not appear to get extracted.
I understand that I need to run autoconf to generate the configure file.
However when I do so I get the following error
autoconf ../rtems-4.10/configure.ac
/bin/m4: unrecognized option `--gnu'
Try `/bin/m4 --help' for more information.
autom4te-2.67: /bin/m4 failed with exit status: 1
I have been unable to update the versionof M4 the link in the following
document
http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_M4
to m4-1.4.7-MSYS.tar.bz2 is incorrect,
Can anyone direct me toward the file that I need.
Regards
Sam
Regards
William
On Tue, Oct 19, 2010 at 6:59 PM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> You can get the RTEMS source from CVS:
> http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
> See the bottom section about tags if you want 4.10. The CVS head is called
> 4.11 at this point in time.
> You might find this getting started a little more up-to-date (and
> streamlined): http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
> -Gedare
> On Tue, Oct 19, 2010 at 1:46 PM, Sam Lost <slostuk at gmail.com> wrote:
>> I have been attempting to follow the Getting Started Guide
>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
>> I reached the stage where I would like to download the source however the
>> link given in the above page of the Getting Start Guide is incorrect.
>> Can someone point me towards the 4.10 RTEMS soure.
>> Regards
>> Sam
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101020/e0f6ec2a/attachment-0001.html>
