Issues with the Getting Starting Guide
Sam Lost slostuk at gmail.com
Thu Oct 21 05:42:36 UTC 2010
Thanks,
I followed the directions and run bootstrap however the bootstrap script
exited with errors.
BTW I am attempting to use Win32 tools.
Regards
Sam
On Thu, Oct 21, 2010 at 12:05 AM, Needell Gerald <jerry.needell at unh.edu>wrote:
> After downloading from CVS, you have to run bootstrap. See:
> http://www.rtems.com/wiki/index.php/Quick_Start
> I hope that helps.
> Jerry
>  On Oct 20, 2010, at 3:48 PM, Sam Lost wrote:
>  Ok I have located an updated version of M4 however I am still unable to
> generate the confiure file required.
> I am run M4 version m4 (GNU M4) 1.4.14
> Regards
> Sam
> On Wed, Oct 20, 2010 at 8:27 PM, Sam Lost <slostuk at gmail.com> wrote:
>> Thanks
>> Thanks, I have downloaded the source from CVS, however files such as
>> configure do not appear to get extracted.
>> I understand that I need to run autoconf to generate the configure file.
>> However when I do so I get the following error
>> autoconf ../rtems-4.10/configure.ac
>> /bin/m4: unrecognized option `--gnu'
>> Try `/bin/m4 --help' for more information.
>> autom4te-2.67: /bin/m4 failed with exit status: 1
>> I have been unable to update the versionof M4 the link in the following
>> document
>> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_M4
>> to m4-1.4.7-MSYS.tar.bz2 is incorrect,
>> Can anyone direct me toward the file that I need.
>> Regards
>> Sam
>>  On Tue, Oct 19, 2010 at 6:59 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>>> You can get the RTEMS source from CVS:
>>> http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
>>> See the bottom section about tags if you want 4.10. The CVS head is
>>> called 4.11 at this point in time.
>>> You might find this getting started a little more up-to-date (and
>>> streamlined): http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
>>> -Gedare
>>>   On Tue, Oct 19, 2010 at 1:46 PM, Sam Lost <slostuk at gmail.com> wrote:
>>>>   I have been attempting to follow the Getting Started Guide
>>>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
>>>> I reached the stage where I would like to download the source however
>>>> the link given in the above page of the Getting Start Guide is incorrect.
>>>> Can someone point me towards the 4.10 RTEMS soure.
>>>> Regards
>>>> Sam
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/dec4e36e/attachment-0001.html>
