Yet more MinGW Build Issues
Sam Lost
slostuk at gmail.com
Thu Oct 21 06:49:02 UTC 2010
Ok, however when I use 4.9 I get the same result:
I issued the following commands
export PATH="/c/opt/rtems-4.9/bin:$PATH
*** Note I think the following document has an error:
http://www.rtems.org/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_Base
as you have to add /c/ to the documented path **
tar xjf rtems-4.9.4.tar.bz2
mkdir rtems-4.9.4-psim
cd rtems-4.9.4-psim
../rtems-4.9.4/configure --target=powerpc-rtems4.9 --enable-rtemsbsp=psim
--enable-cxx --enable-tests=samples
make install
Regards
Sam
On Thu, Oct 21, 2010 at 7:05 AM, Chris Johns <chrisj at rtems.org> wrote:
>> I have been unable to download and bootstrap the 4.10 source so in order
>> to get something working I downloaded 4.9.4
>> ../rtems-4.9.4/configure --target=powerpc-rtems4.10
>> --enable-rtemsbsp=psim --enable-cxx --enable-test=samples
> You cannot mix the tool version and RTEMS version.
> There are interfaces in each part that need to match in-order for things to
> work. If you could mix them we would not have version numbers on the tools.
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/75bfd145/attachment-0001.html>
