Yet more MinGW Build Issues
Sebastian Huber
Thu Oct 21 07:32:15 UTC 2010
On 10/21/2010 09:24 AM, Sam Lost wrote:
> Is version 4.9.4 currently supported, can it be built under MinGW?
Yes, it can be built under MinGW. Check that you have everything in your PATH
and that you use the right tool versions (autoconf, automake, m4, RTEMS tool
chain).
An alternative is to install a RPM based Linux in a virtual machine.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
