Strict aliasing and chains revisited
Till Straumann
strauman at slac.stanford.edu
Thu Oct 21 15:42:09 UTC 2010
On 10/21/2010 12:51 AM, Sebastian Huber wrote:
> On 10/21/2010 01:49 AM, Till Straumann wrote:
>> I didn't think about this carefully but I guess a clean solution
>> would be sacrificing the space for 1 pointer and make the
>> Chain_Control a proper struct comprised of 2 Chain_Nodes.
> The chain is a pivot data structure in RTEMS and some operations are not that
> efficient if you sacrifice the node overlap. Also chain controls are used in
> great numbers (one ready chain per task priority). We should keep that structure.
>> A hacked solution would be making Chain_Control a (hopefully properly
>> packed)
>> union Chain_Control {
>> struct {
>> Chain_Node node;
>> Chain_Node *fill;
>> } head;
>> struct {
>> Chain_Node *fill;
>> Chain_Node node;
>> } tail;
>> } Chain_Control;
> Yes, this is an alternative to the casts. I have no preference here.
I don't think the casts remove the alias problem. The fact
that it doesn't seem to happen doesn't guarantee that the
code is correct (gcc behavior changes).
I would feel more comfortable with a proper declaration,
i.e., avoiding type punning.
> Till, what do you think about the change in watchdoginsert.c?
If there are compiler memory barriers in place then
there should be no problem. You mentioned the barrier
in ISR_Flash() -- is there also a barrier before entry
to the routine? This might not be necessary - I'm travelling
and don't have time + access to the code for proper
analysis, sorry - but we should double-check.
- T.
