(offlist) RE: Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Sat Oct 23 04:53:09 UTC 2010
Ok, I am still unable to compile the 4.10 code under MinGW.
I have followed the directions given (to the letter)
I have installed and reinstalled MinGW 16 times now, however I am still
unable to build.
I have attempted the following MinGW installers
mingw-get-inst-20100831.exe
mingw-get-inst-20100909.exe
however both give the same result.
Using M4 1.4.14 I get the following error when attempting to run bootstrap
./c
./c/src/ada-tests
is already registered with AC_CONFIG_FILES.
../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
configure.ac:57: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status:1
automake: autoconf failed with exit status: 1
This error repeats.
Using M4 1.4.7 I get the following error when attempting to run bootstrap
/usr/bin/m4: unrecongized option --gnu
I have am battling with this for 10 days now and I am still unable to
compile andI am starting to lose the will.
Regards
Sam
On Fri, Oct 22, 2010 at 3:54 PM, Steven Grunza <grunza at ulticom.com> wrote:
> Sam,
> Just a suggestion. I’m running the cygwin tools under WinXP SP3. It’s
> painfully slow with the more recent tools (older tools are faster but have
> severe problems) but I’m able to build RTEMS and the “hello world” and ttcp
> network demo.
> I know you’ve invested a lot into the MinGW path but I thought I would
> mention the cygwin option.
> Steven G.
> PS
> I’m currently trying to find a reasonably fast Linux machine to be my
> build machine because the cygwin build is slooooooow. I just thought you
> might want to take a moment to decide what’s more important. For me it is
> working on my application so even though the cygwin is slow, its running
> now. I’ll upgrade to Linux tools later.
> *From:* rtems-users-bounces at rtems.org [mailto:
> rtems-users-bounces at rtems.org] *On Behalf Of *Sam Lost
> *Sent:* Friday, October 22, 2010 10:00 AM
> *To:* Sebastian Huber
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: Running the Bootstrap Script under MinGW
> Thanks,
> I tried all that, Chris kindly went throught it all step by step yesterday.
> I am runinng Windows XP SP3
> Regards
> Sam
> On Fri, Oct 22, 2010 at 2:44 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> I would delete everything and follow the steps from Chris Johns. Btw.
> which
> Windows version do you use?
> On 10/22/2010 03:36 PM, Sam Lost wrote:
> > Sebastian provided a copy of M4 1.4.7 after installing M4 1.4.7 I now
> > Any ideas I have been battl;ing trying to build either 4.9 or 4.10 under
> > windows for a while now :-(
> > Regards
> > Sam
> > On Fri, Oct 22, 2010 at 5:45 AM, Sam Lost <slostuk at gmail.com
> > <mailto:slostuk at gmail.com>> wrote:
> > I have extracted the RTEMS 4.10 Label from CVS as detailed:
> > http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
> > I am now attempting to run the bootstrap script:
> > http://www.rtems.com/wiki/index.php/Quick_Start
> > However I receive the following errors:
> > ./c
> > ./c/src/ada-tests
> > configure.ac:57 <http://configure.ac:57/>: the top level
> > Any ideas?
> > Regards
> > Sam
> > rtems-users mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
URL: <http://lists.rtems.org/pipermail/users/attachments/20101023/9e8702b8/attachment-0001.html>
