(offlist) RE: Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Sat Oct 23 18:20:14 UTC 2010
Granted I a new to all this however I have a basic question
The RTEMS documents direct the user use M4 1.4.7
I get the following error when attempting to run bootstrap
/usr/bin/m4: unrecongized option --gnu
and as one would expect when I type m4 --gnu I get the same error
M4 1.4.14 I get the following error when attempting to run bootstrap
./c
./c/src/ada-tests
is already registered with AC_CONFIG_FILES.
../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
configure.ac:57: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status:1
automake: autoconf failed with exit status: 1
This error repeats.
So which version of m4 should I use?
Regards
Sam
On Sat, Oct 23, 2010 at 3:30 PM, Sam Lost <slostuk at gmail.com> wrote:
> I extracted the source from CVS using tortise CVS.
> I have not edited the files in anyway.
> Regards
> Sam
> On Sat, Oct 23, 2010 at 7:35 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 23/10/10 06:53, Sam Lost wrote:
>> > Ok, I am still unable to compile the 4.10 code under MinGW.
>> How did you obtain the sources? Maybe this is a UNIX/DOS line ending
>> problem. Try to convert all text files to UNIX line endings.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101023/4a91f14c/attachment-0001.html>
