(offlist) RE: Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Mon Oct 25 09:58:53 UTC 2010
I have just extracted the rtems-4.10-branch again from CVS, this time I
forced Tortoise CVS to use UNIX line endings, however the end result is the
same.
Sam
On Mon, Oct 25, 2010 at 7:58 AM, Sebastian Huber <
> On 10/23/2010 04:30 PM, Sam Lost wrote:
> > I extracted the source from CVS using tortise CVS.
> Tortoise CVS has an option to automatically convert <nl> in <cr><nl> (I
> guess
> this is the default). Please make sure that your sources use the UNIX line
> endings.
> > I have not edited the files in anyway.
> > Regards
> > Sam
> > On Sat, Oct 23, 2010 at 7:35 AM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 23/10/10 06:53, Sam Lost wrote:
> > > Ok, I am still unable to compile the 4.10 code under MinGW.
> > How did you obtain the sources? Maybe this is a UNIX/DOS line ending
> > problem. Try to convert all text files to UNIX line endings.
> > rtems-users mailing list
> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
URL: <http://lists.rtems.org/pipermail/users/attachments/20101025/9cfbb19e/attachment-0001.html>
