Problem with building powerpc-rtems4.11-gcc
Steven Grunza
grunza at ulticom.com
Thu Sep 9 13:55:12 UTC 2010
I'm currently changing build machines from a single CPU CentOS4 box to a
Core2Quad CentOS5 box. Part of the change is the new machine has GCC
4.1.2 instead of 3.4.6. The new machine is also running 64-bit (a first
for me) instead of 32-bit.
Binutils 2.20.1 built and installed ok but gcc 4.5.1 is giving me a
strange error; it looks like the native compiler can't compile the
source to gcc-4.5.1:
make[2]: Entering directory
`/home/grunzasr/rtems_head/tools/b-gcc-ppc/gcc'
gcc -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall
-Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes
-Wmissing-format-attribute -Wold-style-definition -Wc++-compat
-DHAVE_CONFIG_H -DGENERATOR_FILE -I. -Ibuild -I../../gcc-4.5.1/gcc
-I../../gcc-4.5.1/gcc/build -I../../gcc-4.5.1/gcc/../include
-I../../gcc-4.5.1/gcc/../libcpp/include
-I../../gcc-4.5.1/gcc/../libdecnumber
-I../../gcc-4.5.1/gcc/../libdecnumber/dpd -I../libdecnumber \^M
-o build/genmodes.o ../../gcc-4.5.1/gcc/genmodes.c^M
/tmp/cc4psLZx.s: Assembler messages:^M
/tmp/cc4psLZx.s:18: Error: Unrecognized opcode: `movq'^M
/tmp/cc4psLZx.s:21: Error: Unrecognized opcode: `movq'^M
My various tools are:
grunzasr at c2q% gcc --version
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-48)
grunzasr at c2q% autoconf --version
autoconf (GNU Autoconf) 2.67
grunzasr at c2q% automake --version
automake (GNU automake) 1.11.1
grunzasr at c2q% m4 --version
m4 (GNU M4) 1.4.14
autoconf-2.67
automake-1.11.1
binutils-2.20.1
gcc-4.5.1
gmp-5.0.1
m4-1.4.14
mpc-0.8.1
mpfr-2.4.2
newlib-1.18.0
I configured the b-gcc-ppc directory with the following:
../gcc-4.5.1/configure --prefix=/opt/rtems4.11
--target=powerpc-rtems4.11 --with-gnu-as --with-gnu-ld --with-newlib
--verbose --enable-threads --enable-languages="c,c++"
If this didn't build ok on the CentOS4-32bit machine I would just assume
user error but I've run out of things to check. Any suggestions on
what's wrong or where to look?
"Unix is user friendly, it's just Steven Grunza
particular about with whom it voice: (856) 787 - 2759
makes friends." fax: (856) 866 - 2033
- Unknown mailto:grunza at ulticom.com
flames:/dev/null
