VME bus trap ignored
Till Straumann strauman at slac.stanford.edu
Thu Sep 9 17:15:34 UTC 2010
Sorry for the extreme delay. Your message got 'lost' while I was
on vacation a while ago - I just found it.
Is this issue still of interest?
My apologies
- Till
On 08/05/2010 10:49 AM, Wolfgang Rostek wrote:
> Hi all,
> I'm doing some tests accessing VME bus addresses.
> I wonder that an invalid address is somehow tolerated by the Ada/RTEMS
> program but shows a correct trap using dBUG. No Ada exception handler
> seems to get invoked. Is it ok for the program to continue that way?
> The second  assignment 'abcd' I can verify in RAM after restart. (the
> Memory_Address
> function is working for the whole address range)
> tip675_dummy : UNSIGNED_16 := 16#fedc#;
> for tip675_dummy'Address use Memory_Address(16#a0000000#);
> tip675_dummy2 : UNSIGNED_16 := 16#abcd#;
> for tip675_dummy2'Address use Memory_Address(16#40000000#);
> dBUG> md.l a0000000
> md.l a0000000
> A0000000:  FF
> VME Bus Time Out
> PC: F0001474 SR: 2004 [t.Sm.000...xnZvc]
> An: FE000000 F001F830 F001F848 F001F7DD F001F830 CBF5F311 F001F7CC
> F001F7A8
> Dn: 00000000 00008600 00000046 FFFFFF00 00000000 00000008 00000008
> 00000046
> F0001474: 0801 0002            BTST      #0x02,D1
> dBUG>
> Wolfgang Rostek
> Phone: +49 (89) 92 16-2183
> Fax: +49 (89) 92 16-162183
> wolfgang.rostek at esg.de
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100909/f0b0b2db/attachment.html>
