NAND Flash filesystem
Mick Davis
mickd at goanna.iinet.net.au
Fri Sep 10 04:10:01 UTC 2010
I'm looking at implementing a NAND flash filesystem for the
at91sam9263-ek, and hoped there might be some advice available.
The raw flash chip is connected to the processor's on-chip static memory
controller.
I'm not keen to use GPL sources, but I can share my own results.
JFFS2 has a license exception which might make it OK, but porting it
away from Linux seems like an excessive amount of work. Has anyone
succeeded with this? I'd want it to integrate with RTEMS for use with
ordinary system calls.
The most likely option looks like something of my own creation using the
RTEMS block and disk device drivers, along the lines of the existing
RTEMS flashdisk driver.
From what I understand, the flashdisk driver is for NOR flash, and NAND
is quite different. NAND requires that you only program entire pages
sequentially in the block. You can't change the state of an individual
word, even progressively from FFs down to 00s, as the flashdisk driver
does for the page state indications, or for appending new page
descriptors at the start of a block.
For NAND, only whole blocks are erasable, which are much larger than the
programmable pages. The device on the eval board is smaller than the
product I'm developing for, but as an indication it is a 256Mb chip of
128kb blocks, 2kb pages.
I guess a NAND driver might put a descriptor at the start of each page.
Each page would map to a filesystem block (as in filesystem minimum
unit) and use a sequence number to determine the latest version of that
block.
I think its worth considering a new simple implementation because I
don't mind if the chip is under-utilized. Writes are infrequent, so wear
leveling can be crude. The working copy of most file data is kept by my
app in memory anyway, so high speed is not a big requirement either.
Thanks for any input.
Mick Davis
Goanna Technologies Pty Ltd
