RTEMS 4.10 Autoconf tools
Fri Sep 10 06:41:40 UTC 2010
On 10/09/10 4:08 PM, Ian Caddy wrote:
> On 10/09/2010 12:25 PM, Ralf Corsepius wrote:
>> On 09/10/2010 05:30 AM, Ian Caddy wrote:
>>> It looks like the prebuilt mingw tools are out of sync with the 4.10
>>> source.
>> This conclusion is not correct.
>> The prebuilt-tarballs below ftp.rtems.org://pub/rtems/mingw32 and the
>> linux rpms below ftp.rtems.org://pub/rtems/linux are being built from
>> identical sources and normally correspond to the current status of the
>> corresponding rtems version.
>> The packages below ftp.rtems.org://pub/rtems/windows are out of sync and
>> effectively dead - Is it them you are trying to use?
> Yes, as I explained in the top of the original thread, these were the
> tools I was using, which I got from the Wiki:
>> http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows
> which points to the dead (as you explained windows tools).
> This should probably be changed.
Yes it should. If anyone has a little time please update. It would be a
great help.
