NAND Flash filesystem
John Dallaway john at dallaway.org.uk
Sun Sep 12 16:36:19 UTC 2010
Mick Davis wrote:
> I'm looking at implementing a NAND flash filesystem for the
> at91sam9263-ek, and hoped there might be some advice available.
> The raw flash chip is connected to the processor's on-chip static memory
> controller.
> I'm not keen to use GPL sources, but I can share my own results.
> JFFS2 has a license exception which might make it OK, but porting it
> away from Linux seems like an excessive amount of work. Has anyone
> succeeded with this?   I'd want it to integrate with RTEMS for use with
> ordinary system calls.
Have you considered UFFS? It appears to offer some advantages over JFFS2
for deeply embedded applications:
  http://sites.google.com/site/gouffs/
John Dallaway
