Problems getting started with PC686 BSP
Steven Grunza grunza at ulticom.com
Wed Sep 15 14:16:36 UTC 2010
I've been trying to get the hello_world example to work on a Dell laptop
without success.
I've tried with RTEMS source from CVS head and with RTEMS source from
rtems-4-10-branch (in case CVS head had a problem on the day I
downloaded).
I've tried using tools I built and tools installed from .rpm on two
different CentOS 5 x86_64 machines.
I'm using a USB boot from a flash drive (the laptop doesn't have a
floppy drive).
I followed directions from a web site to build a bootable USB drive with
GRUB.  GRUB (0.97) loads and displays the expected menu of selections
from the grub.conf file but none of the three files I try to boot work.
The .ralf is reported as "Error 13: Invalid or unsupported executable
format" and the .exe files leave the laptop with a blank screen.
My grub.conf is:
default=0
timeout=15
title RTEMS pc686-tests-hello.exe
        root (hd0,0)
        kernel /boot/images/pc686-tests-hello.exe
title RTEMS pc686-hello.ralf
        root (hd0,0)
        kernel /boot/images/pc686-hello.ralf
title RTEMS pc686-hello.exe
        root (hd0,0)
        kernel /boot/images/pc686-hello.exe
The file pc686-tests-hello.exe came from
/opt/rtems-4.11/i386-rtems4.11/pc686/lib/rtems-4.10/tests and
/opt/rtems-4.11/i386-rtems4.11/pc686/lib/rtems-4.11/tests after
installing the RTEMS I built and running "make install".
The files pc686-hello.* came from building the hello_world examples.
My USB drive contents are:
J:\>dir /s
 Volume in drive J has no label.
 Volume Serial Number is 4C8F-D1DD
 Directory of J:\
09/14/2010  03:51 PM    <DIR>          boot
               0 File(s)              0 bytes
 Directory of J:\boot
09/14/2010  03:50 PM    <DIR>          .
09/14/2010  03:50 PM    <DIR>          ..
09/14/2010  03:55 PM    <DIR>          images
09/14/2010  03:53 PM    <DIR>          grub
               0 File(s)              0 bytes
 Directory of J:\boot\images
09/15/2010  09:34 AM         1,349,972 pc686-hello.exe
09/15/2010  09:35 AM           187,904 pc686-hello.ralf
09/15/2010  09:33 AM         1,170,079 pc686-tests-hello.exe
               3 File(s)      2,707,955 bytes
 Directory of J:\boot\grub
09/14/2010  03:51 PM    <DIR>          .
09/14/2010  03:51 PM    <DIR>          ..
09/14/2010  03:51 PM             7,584 e2fs_stage1_5
09/14/2010  03:51 PM             7,456 fat_stage1_5
09/14/2010  03:51 PM             6,720 ffs_stage1_5
09/14/2010  03:53 PM               637 grub.conf
09/14/2010  03:51 PM             6,720 iso9660_stage1_5
09/14/2010  03:51 PM             8,224 jfs_stage1_5
09/14/2010  03:51 PM             6,880 minix_stage1_5
09/14/2010  03:51 PM             9,248 reiserfs_stage1_5
09/14/2010  03:51 PM            55,808 splash.xpm.gz
09/14/2010  03:51 PM               512 stage1
09/14/2010  03:51 PM           104,988 stage2
09/14/2010  03:51 PM             7,072 ufs2_stage1_5
09/14/2010  03:51 PM             6,272 vstafs_stage1_5
09/14/2010  03:51 PM             8,872 xfs_stage1_5
              14 File(s)        236,993 bytes
     Total Files Listed:
              17 File(s)      2,944,948 bytes
               9 Dir(s)   2,012,889,088 bytes free
Can someone send me a clue as I apparently don't have one?
