clang-analyze on RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Sep 20 01:21:01 UTC 2010
Hi,
I have run clang-analyze on RTEMS. Running
it on the same subset we run Coverity Scan
on produced no issues. I don't know if clang
will turn up anything but it is another
tool in the arsenal. So I tried to run it
on everything and got this:
checking for style of include used by gmake... GNU
checking for sparc-rtems4.11-gcc...
/usr/lib/clang-analyzer/scan-build/ccc-analyzer
checking for sparc-rtems4.11-gcc... (cached)
checking whether the C compiler works... no
configure: error: in
`/home/joel/rtems-4.11-work/build/gcc-testing/rtems/clang-analyzer/b-clang-sparc-rtems4.11/sparc-rtems4.11/c/sis':
configure: error: C compiler cannot create executables
See `config.log' for more details.
gmake[2]: *** [sis] Error 1
gmake[2]: Leaving directory
`/home/joel/rtems-4.11-work/build/gcc-testing/rtems/clang-analyzer/b-clang-sparc-rtems4.11/sparc-rtems4.11/c'
It is pretty easy to run .. just configure .. then
scan-build -o output_dir make
Any thoughts on why the autoconf test fails?
--joel
