clang-analyze on RTEMS
Ralf Corsepius ralf.corsepius at rtems.org
Mon Sep 20 03:39:02 UTC 2010
On 09/20/2010 03:21 AM, Joel Sherrill wrote:
> Hi,
> I have run clang-analyze on RTEMS. Running
> it on the same subset we run Coverity Scan
> on produced no issues. I don't know if clang
> will turn up anything but it is another
> tool in the arsenal. So I tried to run it
> on everything and got this:
> checking for style of include used by gmake... GNU
> checking for sparc-rtems4.11-gcc...
> /usr/lib/clang-analyzer/scan-build/ccc-analyzer
> checking for sparc-rtems4.11-gcc... (cached)
> checking whether the C compiler works... no
> configure: error: in
> `/home/joel/rtems-4.11-work/build/gcc-testing/rtems/clang-analyzer/b-clang-sparc-rtems4.11/sparc-rtems4.11/c/sis':
> configure: error: C compiler cannot create executables
> See `config.log' for more details.
> gmake[2]: *** [sis] Error 1
> gmake[2]: Leaving directory
> `/home/joel/rtems-4.11-work/build/gcc-testing/rtems/clang-analyzer/b-clang-sparc-rtems4.11/sparc-rtems4.11/c'
> It is pretty easy to run .. just configure .. then
> scan-build -o output_dir make
> Any thoughts on why the autoconf test fails?
Me never having used clang and you not providing sufficient informations
to be able to help, only 2 general remarks:
* General answer from the "top autoconf newbie answering templates' drawer":
Do as autoconf tells you - "See 'config.log' for details"
* Knowing you are building on x86_64, your log message referring to
/usr/lib/clang-ananlyser indicates your "clang"-package is likely
misconfigured/incorrectly installed.
Ralf
