How do I use rtems_termios_bufsize?! No doc!
João Rasta freakforever at gmail.com
Fri Sep 24 15:41:02 UTC 2010
In order to discard hardware issues I now tried the same application on a
more powerful FPGA. Here the leon-3 processor runs at 80MHz and UART
hardware fifos size are doubled to 32 bytes. However the problem is still
the same. Rx works well, the packets received are ok but the packets sent
are not correct.
I suspect of a problem on the driver. If i set a big buffer, 1024 as chris
suggested, "trash" bytes are sent. This does not happen if i set a buffer
lower than the message i want to send but in this case i loose bytes.
Termios is well configured, the simplest way possible. I'm using POSIX rtems
support.
Can that warning on the driver be the problem? Transmissions in interrupt
mode not working well? Is there any other driver i can use?
Best,
JM
On Fri, Sep 24, 2010 at 3:25 PM, João Rasta <freakforever at gmail.com> wrote:
> Sorry, it is this one:
> rtems-4.10-mingw\src\rtems-4.10\c\src\lib\libbsp\sparc\leon3\console
> On Fri, Sep 24, 2010 at 3:15 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 09/24/2010 04:04 PM, João Rasta wrote:
>> > The filename is console.c. I'm using rtems 4.10 from
>> > ftp://gaisler.com/gaisler.com/rcc/src/
>> There are 48 console.c files in this archive.
>> > Best,
>> > JM
>> > On Fri, Sep 24, 2010 at 1:13 PM, Sebastian Huber
>> > <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> >     On 09/24/2010 02:01 PM, João Rasta wrote:
>> >     > Hi,
>> >     > I have checked the termios configuration again, it seems ok. No
>> >     software
>> >     > flow control, no canonical mode. Also the same configuration works
>> >     fine
>> >     > on a x86.
>> >     > I'm using gaisler's console driver and when i opened the rtems
>> driver
>> >     > file it said this:
>> >     What is the file name path of this file and the CVS version in your
>> >     case?
>> >     Sebastian Huber, embedded brains GmbH
>> >     Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> >     Phone   : +49 89 18 90 80 79-6
>> >     Fax     : +49 89 18 90 80 79-9
>> >     E-Mail  : sebastian.huber at embedded-brains.de
>> >     PGP     : Public key available on request.
>> >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>> EHUG.
>> >     _______________________________________________
>> >     rtems-users mailing list
>> >     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> >     http://www.rtems.org/mailman/listinfo/rtems-users
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20100924/50171b99/attachment.html>
