BSP for AT91SAM9263-EK
Johannes Schock j.schock at stiefelgmbh.de
Tue Sep 7 19:09:56 UTC 2010
I use the termios system.
I think the per character basis is caused by the print code used by
Ticker. The code uses several printfs as putchars (buffer_test_io.h):
  #define puts(_s) \
      do { \
         printf( "%s\n", _s ); \
      } while (0)
  #undef putchar
  #define putchar(_c) \
    do { \
       printf( "%c", _c ); \
    } while (0)
Am Dienstag, den 07.09.2010, 20:58 +0200 schrieb Thomas Doerfler (nt):
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Eric,
> Am 07.09.2010 20:54, schrieb Eric Norum:
> > The interleaved values don't seem unreasonable -- the interrupt-driven console output will block thus giving the scheduler a chance to do a context switch.  The polling driver won't do this so the output doesn't interleave.
> in general I agree. It can happen that the output of verious tasks
> intermix in interrupt mode.
> But: What confuses me in the output is that this intermix happens on a
> per character basis. I would expect that it happens with longer chunks
> coming from one task, then from the next etc.
> Johannes, does your console driver use the termios system for interrupt
> output?
> wkr,
> Thomas.
> > On Sep 7, 2010, at 11:44 AM, Johannes Schock wrote:
> >> After several months, I found a week to continue my AT91SAM9263-BSP.
> >> I have the HelloWorld running, but I face a problem with Ticker:
> >> With polled console it works fine, with interrupt driven console the
> >> first three messages of the tasks are written in each other.
> >> Is this a known issue, or do I have a to search for a bug in my console
> >> driver?
> >> *** CLOCK TICK TEST ***
> >> TA1  - rtems_clock_get_tod - 09:00:00   TT12AA/2331  / -
> >> rtems_clock_get_tod -  - rtems_clock_get_tod - 198800
> >> 99::0000::0000      1212//3131//19881988
> >> TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
> >> TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
> >> TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
> >> TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
> >> TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
> >> TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
> >> TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
> >> TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
> >> TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
> >> TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
> >> TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
> >> *** END OF CLOCK TICK TEST ***
> >> _______________________________________________
> >> rtems-users mailing list
> >> rtems-users at rtems.org
> >> http://www.rtems.org/mailman/listinfo/rtems-users
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>      http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iD8DBQFMhotbwHyg4bDtfjQRAp+nAJ9iP6wKwCIN0aVpUE2jDzkpvBCoGACeNEi5
> ZAn/kwJGjBYZnR9QweKjqRA=
> =s50d
> -----END PGP SIGNATURE-----
