BSP for AT91SAM9263-EK
Johannes Schock
j.schock at stiefelgmbh.de
Tue Sep 7 19:20:05 UTC 2010
Am Dienstag, den 07.09.2010, 14:13 -0500 schrieb Joel Sherrill:
> On 09/07/2010 02:09 PM, Johannes Schock wrote:
> > I use the termios system.
> > I think the per character basis is caused by the print code used by
> > Ticker. The code uses several printfs as putchars (buffer_test_io.h):
> It is likely the macros that print the time and date being multiple
> calls.
> -joel
According to all your messages I think I can stop searching for bugs in
my console code. It seems to be reasonable behaviour.
BTW: Wouldn't this be a good possibility for me to use my first
semaphore?
> > #define puts(_s) \
> > do { \
> > printf( "%s\n", _s ); \
> > } while (0)
> > #undef putchar
> > #define putchar(_c) \
> > do { \
> > printf( "%c", _c ); \
> > } while (0)
> > Am Dienstag, den 07.09.2010, 20:58 +0200 schrieb Thomas Doerfler (nt):
> >> -----BEGIN PGP SIGNED MESSAGE-----
> >> Hash: SHA1
> >> Eric,
> >> Am 07.09.2010 20:54, schrieb Eric Norum:
> >>> The interleaved values don't seem unreasonable -- the interrupt-driven console output will block thus giving the scheduler a chance to do a context switch. The polling driver won't do this so the output doesn't interleave.
> >> in general I agree. It can happen that the output of verious tasks
> >> intermix in interrupt mode.
> >> But: What confuses me in the output is that this intermix happens on a
> >> per character basis. I would expect that it happens with longer chunks
> >> coming from one task, then from the next etc.
> >> Johannes, does your console driver use the termios system for interrupt
> >> output?
> >> wkr,
> >> Thomas.
> >>> On Sep 7, 2010, at 11:44 AM, Johannes Schock wrote:
> >>>> After several months, I found a week to continue my AT91SAM9263-BSP.
> >>>> I have the HelloWorld running, but I face a problem with Ticker:
> >>>> With polled console it works fine, with interrupt driven console the
> >>>> first three messages of the tasks are written in each other.
> >>>> Is this a known issue, or do I have a to search for a bug in my console
> >>>> driver?
> >>>> *** CLOCK TICK TEST ***
> >>>> TA1 - rtems_clock_get_tod - 09:00:00 TT12AA/2331 / -
> >>>> rtems_clock_get_tod - - rtems_clock_get_tod - 198800
> >>>> 99::0000::0000 1212//3131//19881988
> >>>> TA1 - rtems_clock_get_tod - 09:00:05 12/31/1988
> >>>> TA1 - rtems_clock_get_tod - 09:00:10 12/31/1988
> >>>> TA2 - rtems_clock_get_tod - 09:00:10 12/31/1988
> >>>> TA1 - rtems_clock_get_tod - 09:00:15 12/31/1988
> >>>> TA3 - rtems_clock_get_tod - 09:00:15 12/31/1988
> >>>> TA1 - rtems_clock_get_tod - 09:00:20 12/31/1988
> >>>> TA2 - rtems_clock_get_tod - 09:00:20 12/31/1988
> >>>> TA1 - rtems_clock_get_tod - 09:00:25 12/31/1988
> >>>> TA1 - rtems_clock_get_tod - 09:00:30 12/31/1988
> >>>> TA3 - rtems_clock_get_tod - 09:00:30 12/31/1988
> >>>> TA2 - rtems_clock_get_tod - 09:00:30 12/31/1988
> >>>> *** END OF CLOCK TICK TEST ***
> >>>> _______________________________________________
> >>>> rtems-users mailing list
> >>>> rtems-users at rtems.org
> >>>> http://www.rtems.org/mailman/listinfo/rtems-users
> >> IMD Ingenieurbuero fuer Microcomputertechnik
> >> Thomas Doerfler Herbststrasse 8
> >> D-82178 Puchheim Germany
> >> email: Thomas.Doerfler at imd-systems.de
> >> PGP public key available at:
> >> http://www.imd-systems.de/pgpkey_en.html
> >> -----BEGIN PGP SIGNATURE-----
> >> Version: GnuPG v1.2.5 (MingW32)
> >> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> >> iD8DBQFMhotbwHyg4bDtfjQRAp+nAJ9iP6wKwCIN0aVpUE2jDzkpvBCoGACeNEi5
> >> ZAn/kwJGjBYZnR9QweKjqRA=
> >> =s50d
> >> -----END PGP SIGNATURE-----
