How do I use rtems_termios_bufsize?! No doc!
Thu Sep 30 12:05:06 UTC 2010
  On 09/30/2010 06:54 AM, João Rasta wrote:
> Hi all,
> Finally i got this issues all solved (at least for now). I struggled a
> bit to get the APBUART rtems driver working, i had to make a slight
> modification to the driver so it could coexist with the console driver
> for the stdio dedicated UART and figure out some undocumented stuff
> about the driver manager initialization. The APBUART driver worked
> correctly and i see no problems using the UART assigned to APBUART
> driver in full-duplex mode, contrary to what happened to the console
> driver (console.c).
Great.. Patches, README? :-D
--joel
> Best,
> JM
> On Mon, Sep 27, 2010 at 6:58 PM, João Rasta <freakforever at gmail.com
> <mailto:freakforever at gmail.com>> wrote:
>     Hi all,
>     Well i have been able to reproduce the problem. Instead of the
>     previous host (dSPACE), i used a PC as a host and implemented a
>     simple application to perform both reads and writes via the serial
>     link to the FPGA board running rtems. The rtems software simply
>     performs writes() to the serial line at a fixed rate. I saw that:
>     1) If the rtems running on the FPGA board only sends data to the
>     host, it's OK.
>     2) Instead of only reading, if the host also writes, even if there
>     are no read()'s at the rtems side which only keeps write()'ing, i
>     start to loose bytes received at the host side.
>     Since there are two independent Rx and Tx lines, i did not expect
>     this to occur. Also, there are two separated hardware fifos for
>     both Tx and Rx and since i have no read()'s on the rtems side i
>     expect no software calls when bytes arrive, hence no software
>     overheads.
>     What am i missing?
>     Best,
>     JM
>     On Fri, Sep 24, 2010 at 4:41 PM, João Rasta
>     <freakforever at gmail.com <mailto:freakforever at gmail.com>> wrote:
>         In order to discard hardware issues I now tried the same
>         application on a more powerful FPGA. Here the leon-3 processor
>         runs at 80MHz and UART hardware fifos size are doubled to 32
>         bytes. However the problem is still the same. Rx works well,
>         the packets received are ok but the packets sent are not correct.
>         I suspect of a problem on the driver. If i set a big buffer,
>         1024 as chris suggested, "trash" bytes are sent. This does not
>         happen if i set a buffer lower than the message i want to send
>         but in this case i loose bytes.
>         Termios is well configured, the simplest way possible. I'm
>         using POSIX rtems support.
>         Can that warning on the driver be the problem? Transmissions
>         in interrupt mode not working well? Is there any other driver
>         i can use?
>         Best,
>         JM
>         On Fri, Sep 24, 2010 at 3:25 PM, João Rasta
>             Sorry, it is this one:
>             rtems-4.10-mingw\src\rtems-4.10\c\src\lib\libbsp\sparc\leon3\console
>             On Fri, Sep 24, 2010 at 3:15 PM, Sebastian Huber
>             <sebastian.huber at embedded-brains.de
>             <mailto:sebastian.huber at embedded-brains.de>> wrote:
>                 On 09/24/2010 04:04 PM, João Rasta wrote:
>                 > The filename is console.c. I'm using rtems 4.10 from
>                 > ftp://gaisler.com/gaisler.com/rcc/src/
>                 There are 48 console.c files in this archive.
>                 > Best,
>                 > JM
>                 > On Fri, Sep 24, 2010 at 1:13 PM, Sebastian Huber
>                 <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>                 >     On 09/24/2010 02:01 PM, João Rasta wrote:
>                 > > Hi,
>                 > > I have checked the termios configuration again, it
>                 seems ok. No
>                 >     software
>                 > > flow control, no canonical mode. Also the same
>                 configuration works
>                 >     fine
>                 > > on a x86.
>                 > > I'm using gaisler's console driver and when i
>                 opened the rtems driver
>                 > > file it said this:
>                 >     What is the file name path of this file and the
>                 CVS version in your
>                 >     case?
>                 >     Sebastian Huber, embedded brains GmbH
>                 >     Address : Obere Lagerstr. 30, D-82178 Puchheim,
>                 Germany
>                 >     Phone   : +49 89 18 90 80 79-6
>                 >     Fax     : +49 89 18 90 80 79-9
>                 >     E-Mail  : sebastian.huber at embedded-brains.de
>                 >     PGP     : Public key available on request.
>                 >     Diese Nachricht ist keine geschäftliche
>                 Mitteilung im Sinne des EHUG.
>                 >     _______________________________________________
>                 >     rtems-users mailing list
>                 > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>                 <mailto:rtems-users at rtems.org>>
>                 > http://www.rtems.org/mailman/listinfo/rtems-users
>                 Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>                 Diese Nachricht ist keine geschäftliche Mitteilung im
>                 Sinne des EHUG.
