M68K (mcpu=cpu32)issues with latest tool chain
Kirspel, Kevin kevin.kirspel at optimedical.com
Fri Apr 1 19:32:51 UTC 2011
I downloaded the latest tool chains (binutils-2.21, gcc-4.5.2, newlib-1.19.0) and compiled RTEMS successfully.  When running the application I get failures in most newlib string functions (strcmp, strncpy, etc.).  My previous tool chain running 4.9 is: binutils-2.18, gcc-4.3.2, newlib-1.18.0 (which has no problems).  There is not a lot of differences between newlib-1.18.0 and newlib-1.19.0 other than  references to intptr_t instead of long.    I replaced intptr_t with long to see if it made any difference and it does not.  I forced the code to take the non optimized path (the slow method) and everything works OK.  Does anyone know what might be causing the issue?
Kevin Kirspel
Senior Electrical Engineer
Opti Medical
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
URL: <http://lists.rtems.org/pipermail/users/attachments/20110401/698c18df/attachment.html>
